AUDIOPHONICS I-Sabre DAC ES9018K2M Raspberry Pi 3 / Pi 2 A+ B+ / I2S
Reference : 11500
119,00 €tax incl.
99,17 € tax excl.
es9018k2m audiophonicsThis new CADAUDIOPHONICS I-SABRE ES9018K2Mallows you to access the High Resolution 32bit 384KHZ directly compatible on Rapsberry Pi.
TheDAC I-SABRE ES9018K2Mincludes a power input directly to 5V micro USB input. This input has an isolator (voltage isolation 3000VDC).
Special attention is given to the power supply with two controllers followed by capacitors ensuring the necessary stability for the DAC ESS SABER 32bit.
Like all DAC dedicated Raspberry PI on GPIO support, The AUDIOPHONICS I-SABRE ES9018K2Mincludes a large number of options. It thus allows to adapt to all the possibilities and project DIY HIFI.
Advanced analog outputs on 3 AOP NJM 2114D:
JRC 2114 ES9018K2MThis DAC includes a voltage stage with two AOP NJM 2114D corresponding to the technical drawings of ESS. A final AOP NJM2114 buffer finalizes the output stage.
A fully programmed microcontroller:
es9018k2m audiophonicsThis DAC includes an integrated controller programmed by our development team. Depending on the firmware used, you can control the 32 bit digital volume of the ESS SABER DAC.
Ce 32-bit volume with 64bit accumulator is the most powerful on the market. It also allows the volume management of the ES9018K2m in hardware via a kit button soon available.
An optional high-quality display:
es9018k2m audiophonics This optional screen of the most readable indicates the bit-rate, volume and various information from the DAC. It will suffice to connect it on 4 wires on the card of the DAC. it is managed by the microcontroller on the card.
It shows the main sampling frequencies, the I2S input and the volume level at the Décibel pré. Several sizes of screens will be available depending on the project or the desired assembly.
Outdoor power supply:
es9018k2m audiophonics OLEDThis DAC has an input on the circuit making it possible to input a voltage of 5V DC regulated directly on the ESS SABER ES9018K2M without going through the internal regulation. It is thus possible to further increase the decoding accuracy by any quality linear power supply. This DAC ES9018 K2M also allows the supply of Pi 3 or Pi 2 via the GPIO connector avoiding multiple unnecessary connections simplifying the arrangement of a case.
This DAC IS COMPATIBLE with REclocker 44 / 48MHZ ALLO KALI
es9018k2m audiophonics allo kali 44/48
Features:
  • Low noise control of the power supply for a maximum power supply of 5VDC (2A)
  • PCM analog digital conversion (32bit / 384khz Max) with non-native DSD reading
  • I2S input on the card
  • Option for microcontroller screen on the DAC board. (Volume, Bit Rate)
  • Software ESS Hardware ESS Hardware Volume Capability
  • Possibility to shunt the internal regulation 5V for a superior power supply.
  • Supply of Pi 2 or Pi 3 by the DAC
  • Infrared IR connection on GPIO port 26
  • Ultra Low Precision Clock jitter
  • Input: Raspberry PI 2.0 PI3.0 GPIO
  • Output: RCA stereo high quality gold plated
  • Analogue stage: 3x AOP NJM2114D
  • Mounting holes (HAT format): 50mm x 58mm
  • RCA sockets: 20 mm spacing, drilling diameter 12 mm
  • I2S driver: ISABRE DAC on Rune Audio
  • PCB Dimensions: 85x56x29mm
CONFIGURATION OF THE DAC AUDIOPHONICS ES9018K2M
We provide a RuneAudio image with the RPI-DAC driver which upsample in 24bit
(compatible with all modes)
For Bitperfect the Hifiberry driver can be used in conjunction with the serial script.
The LED display and various accessories such as the case or the Raspberry Pi are sold separately.
Can be used with:
Raspberry Pi 2 1GB HDMI 1.4 USB 2.0 1080p
Raspberry Pi 3 1GB HDMI Ethernet 4xUSB 1.2Ghz
Recommended accessories:
Spacer Brass M2.5x11mm screw thread (x10)
Compatible Enclosures:
KIT Ultra Flat Aluminum Case for Raspberry Pi 3 / Pi 2
Aluminum Case for I-Sabre DAC V2 / V3 & Raspberry Pi 3 / Pi 2 B
Aluminum housing for Raspberry Pi 3 / Pi 2 and I-Sabre ES9023 V2 / V3
RaspTouch DIY Kit Aluminum Chassis and Accessories Black
RaspTouch DIY Kit Aluminum Chassis and Accessories with 7 "Touch Screen Black
E1.3-inch OLED compatible with DAC
Compatible Power Supplies:
AUDIOPHONICS Regulated Linear Power Supply Low Noise USB 5V 3.5A 25VA Audiophonics
DAC Management and Connections
Type of operation
CONTROLLER
DAC
MANAGEMENT volume and functions
INPUT I2S
DISPLAY screen
Things to do on the ES9018K2M
SLAVE MODE 1
The controller is disabled, the monitor output is not active
The DAC can be operated with a Pi2 / 3 or a 24-32 bit I2S source
Rune Audio manages software volume
The I2S input accepts 24-32 bit
OLED output disabled
Jumper welding IC or grounded
Photo A.
STAN MODEDALONE 2
The controller is active in master
The DAC is self-contained, no need for Pi2 or Pi3
The volume and the mute are managed by the DAC in hardware mode with buttons
The I2S input accepts 16 / 24-32 bit depending on the MUTE pin (GND or 5V)
Bitrate and Volume displayed on a dedicated Oled screen
The IR pin must be GND
Mute 0: 24bit-32bit
Mute 1: 16bit
SERIAL HARDWARE MODE
The controller is synchronized with the PI in serial connection
The DAC needs the serial script to be driven
The volume is in hardware mode (serial synchronization)
The I2S input accepts 16 / 24-32 bit depending on the serial message
the IR pin must be at + 5V
Script serie PIN TX (PIN8 GPIO14)
An image of RuneAUDIo is available here:
RUNEAUDIO ES9018K2M
Connection Micro USB to 5.5 / 2.5 jack for RaspDAC
Purchase this connector (click on the link): jack 5.5/2.5
adaptateur 5.5/2.5
Input
  • I2S
Channel
  • 2 (Stereo)
Aucun son à 16/44 bits
Ik gebruik de laatse versie van Volumio, maar geen sabre driver en geen geluid bij 16/44 bit
Bonjour,
Vous utilisez certainement un système sur base MPD posant des soucis de décodage 16bit.
Favorisez une solution comme Picoreplayer fonctionnant parfaitement avec ce DAC.
This review has been posted for AUDIOPHONICS I-Sabre DAC ES9018K2M Raspberry Pi 3 / Pi 2 A+ B+ / I2S
