DAC ISabre ES9028Q2M, avec le reclocker Kali et l'alim linéaire régulée, cable Mogami 3104 en bi-cablage sur des Tannoy D700. C'est le top.
Je n'aurais jamais cru que mes CD étaient aussi bons.
Strong points :
Our Audiophonics DAC ES9028Q2M has been updated to version ES9038Q2M.
Find this version ES9038Q2M on this page.
DAC 32bit 768kHz / I2S & SPDIF
Audiophonics offers many improvements to its ES9028Q2M IAC Sabre DAC, especially in terms of functionality, while still offering exceptional sound performance.
Like its predecessors, the ES9028Q2M delivers truly exceptional sound performance with selected components to ensure the most accurate and clean sound reproduction. Thus, it supports sampling rates up to 32bit 768kHz. Based on proven technologies, the 32bit Hyperstream offers a wider range of dynamics while drastically reducing the jitter that could lead to distortion.
Like its predecessors, the ES9028Q2M fits perfectly with Raspberry Pi to offer a complete, flexible and powerful DAC. This converter innovates by offering a real hardware control, allowing it to operate in full autonomy, via its input I2S. In addition, installing drivers is no longer required for pto allow the operation of the DAC. These come only in addition to bring you a software management of your device.
The 9028Q2M, in order to facilitate its use and ensure a high stability is loaded, via its microprocessor, to automatically detect the sampling rate of the source to adapt automatically. Thus, there is no problem decoding the signal and no artefact will appear listening.
Including two AOP NJM 2114 powered by 12V on the map corresponding to ESS technical drawings, the latest AOP NJM 2114 buffer finalizes the analog output stage, to ensure optimal playback.
This converter also represents a truly complete solution, allowing you to add a high quality OLED screen for the display of sources, volume and bit rate, as well as a physical volume controller to be able to adjust.the volume simply, without having to go through a software or an application.
Warning: This product contains only the Audiophonics I-Sabre ES9028Q2M DAC. The RaspBerry Pi, OLED screen, rotary encoder, and Kali are sold separately.
Powered by a Micro USB 5V input, the DAC has a particularly well-designed power stage that both ensures a stable signal while reducing residual noise. For this, the PCB incorporates a Mornsun DC / DC converter providing voltage isolation of 3000VDC followed by two regulators and two 16V capacitors for stability.
In addition, as for its predecessor the Raspberry Pi can be powered directly via the GPIO port, thus avoiding multiple connections. You are also free to use a quality linear power supply to further improve the accuracy of decoding.
Our I-SABRE ES9028Q2M DAC is 100% compatible with the Open Source DietPi solution.
This solution allows to install a dedicated driver to directly control the DAC, and thusrofiter of ESS hardware volume control.
This can attenuate the output signal without losses, and thus use the DAC as a true preamplifier
The Dietpi solution is recommended to use Logitech Media server and / or ROON. But also allows to install other applications. Computer skills (SSH connection) are nevertheless necessary to correctly program this solution.
Click on the following logo to discover their site and their solutions to download.
DietPi Mixer
The ES9028Q2M is also compatible with the Volumio solution. Thus, it offers a web control interface that is both efficient and intuitive. What to enjoy fully and simply your music in high resolution.
The DAC-ISABRE is 32bit 384KHZ compatible with the MoOde AUDIO distribution
To reach the 32 / 384Khz under MoOde Audio use the Advanced RT kernel:
Connectors | |
inputs | 1x GPIO (for Rasberry Pi) 1x I2S 1x SPDIF |
Exits | 1x RCA Stereo |
Sampling rate | Up to 32 bit 768kHz (384k for RPI) DSD 128 DOP auto switch |
Dynamic range | 129dB |
THD + N | -120dB |
Dimensions | 57 x 90mm |
Weight | 40g |
Food | Micro USB-B 5V (not included) |
Attention, to connect a Raspberry Pi on the GPIO port, an additional connector is necessary.
raphe_standard ">
Average votes 5.0 / 5 8 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Claude T.
Gerard l.
Stefano b.
Audier J.
Cyril V.
