AUDIOPHONICS I-TDA1387 TCXO DAC Raspberry Pi 3 / A+ B+ / Pi 2 / I2S
4.9 / 5
Reference : 11585
54,90 €tax incl.
45,75 € tax excl.
The DAC for Raspberry Pi Audiophonics TDA 1387 X8 is in the line of the vintage converters with typical 16bit analog sound TDA1541 R2R and TDA1543 R2R. This TDA 1387 DAC is the improved suite in Continuous calibration DAC (CC-DAC) version.
This continuous calibration technology has the advantage of being insensitive to component ageing, applied load or temperature variation.
It therefore takes up the subjective advantages of R2R DACs by providing "sonic" stability without the dissonance effects of the more recent sigma delta DACs. The sound is melodic, warm while bringing details and high level dynamics. Composed of 8 DACs in parallel, the conversion distortion rates are very low.
Equipped with a TCXO full format 0.5PPM clock, it will bring a real musical emotion to all Raspberry Pi 2 or Pi3 owners wishing to recover the original sound of their audio files. This DAC can also be used as a 6-pin I2S (XHP format) input. (The Masterclock is generated by the DAC).
A bewitching DAC with 192khz compatible analog sound with high level passive components and gold-plated RCA connectors with PTFE insulation.
Audiophonics recommends the following USB I2S interfaces:
Features:
  • I2S input on 6-pin XHP connecto
  • 5V input on 5.5/2.1 jack connector (Remove the jumper if the PI is powered by the Micro USB port)
  • Input: Raspberry PI B+ A+ 2.0 GPIO PI3 and I2S
  • Output: High quality gold-plated RCA with PTFE insulation
  • Supported sampling rates: 16bit 192 kHz (24bit playback possible)Output level: 2V
  • Clock TCXO 50MHZ 0.5ppm
  • No welding required
Dimensions and weights:
  • Centre distance: 85 x 56 mm
  • PCB dimensions: 85x56x36mm
Compatibility linux Pi :
  • I2S driver: GENERIC RPI DAC and HIFIBERRY DAC
  • Fixed volume under Volumio in bitperfect
20mm M2.5 spacers and nuts supplied.
https://www.audiophonics.fr/images2/picoreplayer.jpg
Input
  • I2S
Mounting type
  • To connect
Channel
  • 2 (Stereo)
9 reviews
Warm smooth detailed and wel placed sound
Ordered this one ... V2 DAC ES9023 TCXO, but got the TDA1387 instead and oh am I happy. Thanks to this DAC and my Audiotronics LR-2500 X (1972) and HECO speakers, the sound in my workshop is way better than in my living room ... the warm smooth detailed and wel placed sound supprised me.
This review has been posted for AUDIOPHONICS I-TDA1387 TCXO DAC Raspberry Pi 3 / A+ B+ / Pi 2 / I2S
un bon en avant
Mon matériel cinema - son: Un ampli yamaha rs 600,enceinte kcs série 1500, raspberry B +. Avant : bon son convenant bien à mon épouse et à moi même.
Après changement : tout est devenu charnu et détaillé. La trompette de Miles sonne dans human nature avec une couleur que je n'avais jamais entendu avant. The scope de Manu Katché est fin et percutant. Renée Fleming se déploie dans mon salon. J 'adorre. Prochaine évolution l 'abonnement chez Qobuz
Excellent dac
Comparé au Allo Boss et au Topping D10 ce dac est tout simplement parfait, le Boss délivre des basse un peu trop artificielles et un son légèrement brouillon et le Topping (ESS ES9018K2M) est si hyper détaillé qu'il fatigue parfois mes oreilles. Le TDA 1387 nous offre un son parfaitement équilibré. Bravo Audiophonics pour cette belle réussite.
PS: je me demande toujours à quoi sert le TCXO ;-)
Bon DAC avec AMANERO
J'ai combiné ce DAC avec un AMANERO pour avoir un DAC pour mon ordinateur. Il fonctionne très bien et le son est très rond. Il manque un rien dans les hautes fréquences mais rien de grâve.
Wow ...
It's very enjoyable
