This product is supplied as a DIY kit (Raspberry Pi & DAC not included). This kit does not require any welding on your part. The button and the screen are already there, you just have to plug and screw.
Audiophonics DAC Network Player for Raspberry Pi 3
Designed around a 100% Aluminum housing to accommodate the modules of your choice as well as all the necessary components, the RaspDac is developed directly in our workshops.
Kit Complete network reader with only the Raspberry Pi, the DAC and the software solution of your choice (Volumio, Picoreplayer, Raspbmc, Openelec).
It will allow you to get very simply a high-end Audio or Audio / Video player. It has all the inputs / outputs necessary for its connector, its power (jack DC 5.5 / 2.1mm), an HDMI port and an OLED display.
He wasdesigned to allow you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a powerful audio solution and achieved an excellent value for money.
display | OLED |
Holes for | 1x RJ45 / 4x Port USB-A / 1x Port HDMI / 1x Port Analog Output RCA Stereo / 1x Input Jack DC 5.5 / 2.1mm |
Dimensions | 160 x 140 x 50mm |
Display Size | 65 x 16mm |
Weight | 0.9kg |
Housing material | 100% Aluminum |
Color | Black |
This 100% Aluminum case has been designed to receive the Raspberry Pi 2 Model B coupled with an I-Saber DAC V3.
It will however be necessary to provide mains power to 5V with USB A 2A connector (or connect it to a computer).
Contents of the kit
