AUDIOPHONICS RASPDAC Kit DIY Streamer for Raspberry Pi 2 / 3 & DAC
This RaspDAC kit contains the Aluminum case, button, display, HDMI extension, Micro SD extension cable and the necessary hardware to mount your DIY network drive. DAC and Raspberry Pi are not supplied.
4.7 / 5
Reference : 11137
99,00 €tax incl.
82,50 € tax excl.
This product is supplied as a DIY kit (Raspberry Pi & DAC not included). This kit does not require any welding on your part. The button and the screen are already there, you just have to plug and screw.
We also offer the mounted version: RaspDAC Network Reader for Raspberry Pi .
Audiophonics I-Saber V3 ES9023 and Raspberry Pi 3 Network Player
RaspDAC
Designed around a 100% Aluminum case to accommodate the modules of your choice as well as all the necessary components, the RaspDac is developed directly in our workshops. This evolution also includes a slot for micro SD card slot, slot for infrared receiver.
Network Reader Kitt Raspberry Pi, the DAC and the software solution of your choice (Rune Audio, Picoreplayer, Raspbmc, Openelec).
Illustration with the Raspberry Pi 3.0 and the DAC I-Saber V3 ES9023 TCXO (not supplied).
A high-end audio player kit ...
It will allow you to get very simply a high-end Audio or Audio / Video player.
It has all the inputs / outputs necessary for its connection, its power supply (Jack DC 5.5 / 2.1mm), an HDMI port, a piercing for infrared receiver, an emplmicro SD card slot, as well as an OLED display.
RaspDAC
Your Raspberry Pi in a high quality Audio environment.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility of having a high performance audio solution and achieves excellent value for money.
DisplayOLED
Holes for1x Micro SD / 1x RJ45 port / 4x USB-A / 1x ports HDMI / 1x port Analog output RCA stereo / 1x Input Jack DC 5.5 / 2.1mm / 1x Infrared receiver
Dimensions160 x 140 x 50mm
Display Size65 x 16mm
Weight0.9kg
Housing material100% Aluminum
This kit contains:
  • 1x RaspDAC aluminum housing
  • 1x monostable switch for DAC Saber V3
  • 1x OLED display 16x2 characters with its tablecloth
  • 1x HDMI dongle cable for rear panel
  • 1x extension for Micro SD card reader rear cover
  • 1x pack spacers for Raspberry Pi and DAC Saber V3 (4 spacers M2.5x20mm Male / Female + 6 spacers M2.5x5mm Male / Female + 6 nuts)
To use this kit without DAC Saber V3 and without ATX power control it is necessary to use a bistable switch
MaterialMetal
3 reviews
5 ans après
RAS tout marche si vous ne modifiez rien au niveau software (sur Volumio 2.619
This review has been posted for AUDIOPHONICS RASPDAC Kit DIY Streamer for Raspberry Pi 2 / 3 & DAC
realisation
realisation de belle facture, petit bémol il m'a été livré un cable HDMi en deux partie, j'aurais prefere de ne pas avoir de raccord un peu long dans le cas present pour mettre dans le boitier
Petit Problème
Heureux de recevoir ce boitier de fort bel ouvrage propre dans tous les details tout s'y adapte parfaitement, mais quelques problèmes surviennent au moment du montage de la carte raspberry P3 celle ci se trouve collée au plus près du P-spc Atx, mais plus grave la sortie adapteur 5v type micro Usb de la ES9028Q2m n'est pas adaptée pour le Boitier tracé CNC Sortie Jack le câble Hdmi est en deux sections ce qui le trop à l'interieur de celui-ci.
This RaspDAC kit contains the Aluminum case, button, display, HDMI extension, Micro SD extension cable and the necessary hardware to mount your DIY...
