DAC AKM AK4399 I2S vers Analogique 32bit/192khz
Reference : 11028
44,90 €tax incl.
37,42 € tax excl.
This DAC AKM converterAK4399 I2S 32bit 192Khzdelivers a rich and detailed sound. It will be the ideal companion for any dematerialized source with quality clock having an I2S output driving this DAC equipped with an I2S input.
Since this DAC does not have a dedicated clock, it is necessary in most assemblies to provide a masterclock reference via the "MCK" pin on the I2S input.
In addition, this DAC has a 5V regulation (LT1085)separated to power an interface USB type I2S Amanero or equivalent not provided. So you can afford an affordable 32bit 192kHz DAC with an I2S USB interface with a very low jitter clock. A 230V transformer must be connected to 1x7 ~ 9V on the optional connector.
This AKM DAC is equipped with high quality passive components with well-known film and electrolytic capacitors. The amplifier JRC 5532DDon DIP 8 support can be changed by a more powerful model making it possible to adapt the sound of the analog part to its liking.
This DAC AKM AK44399 I2S will be the perfect converter for a Raspeberry Pi with a USB interface I2S Amanero, XMOS.
Features:/ Strong>
  • Inputs I2S: DATA / BCK / LRCK / MCK / GND
  • Decoding up to 32Bit 192KHz by AK4399
  • THD + N: -105dB
  • Signal-to-Noise Ratio 123 dB
  • Analog outputs onRCA Stereo Gold Plated
  • Supply via a single transformer:30VA 2x12V(Not supplied)
  • Optional power supply 7 ~ 9V for the 5V regulated part (Amanero and XMOS)
  • Dimensions of the main board: 100 x 63 x 40 mm
Can be used with USB interfaces:
[Img-17416-left-thickbox_default]
[Img-17411-left-thickbox_default]
InputI2S
Channel2 (Stereo)
