DAC ES9038Q2M Module I2S Coaxial Optical 32bit 384kHz DSD
This module is equipped with the excellent latest generation DAC ESS ES9038Q2M. This one offers very high flight digital-to-analog conversion performance. Taking advantage of HyperStream II technology, it will provide your system's playback both dynamic and detail, while reducing jitter and noise.
4.0 / 5
Reference : 12933
DAC ES9038Q2M
DAC ES9038Q2M I2S 32bit 384kHz DSD DoP Coaxial Optical
DAC ES9038Q2M
DAC ESS ES9038Q2M
This module is equipped with the excellent latest generation DAC ESS ES9038Q2M. This one offers very high flight digital-to-analog conversion performance. Taking advantage of HyperStream II technology, it will provide your system's playback both dynamic and detail, while reducing jitter and noise. In addition, it is capable of withstanding high sampling rates, which will delight the most audiophiles. So you can enjoy PCM playback up to 32bit 384kHz and DSD56.
In addition, the DAC includes several PCM filters, which will allow you to adapt the playback to your listening type or music:
  • Fast roll-off minimum
  • Slow roll-off minimum
  • Fast roll-off Linear
  • Slow roll-off Linear
  • Brickwall filter
  • Hybrid fast roll-off
  • Apodizing fast roll-off
The DAC is also supported by good components since we find for example on the PCB an AOP mounted on DIP8 NJM5532DD, interchangeable to adapt the restitution to your listening, or a clock 100MHz allowing to decrease the jitter. RCA and 3.5mm jack connectors benefit from gold plating for better conductivity.
TFT Display & Rotary Encoder
This DAC module comes with a TFT display that will allow you to enjoy a convenient display for viewing information and playback settings. This display will show the sample rate of the played file, the source, the file format (PCM/DSD), the volume attenuation level and the selected filter.
Of course, to be able to act on these parameters, the screen is accompanied by a rotary encoder. This will allow you to simply change source, filter and adjust volume.
  • Rotation to the left : Decrease the volume
  • Rotation vers la droite : Increase the volume
  • Short press : Change input
  • Long press : Change filter
In addition, the display module is equipped with an IR LED. For example, you can use a Metal Apple IR remote control (not included) to remotely control your DAC.
Once the screen is connected, you must set a jumper on J1 and J2 in order for it to work.
Écran TFT
Note about the power supply of this module (not supplied) It is possible to power this module in two different ways. It is recommended to use a +15V / -15V linear power supply. However, it is also possible to use a 15V AC adapter and power the module via the DC jack connector. If you choose this second option, we recommend performing a spot weld on the "J6" points of this module.
DACESS ES9038Q2M
Supported sampling rateCoaxial : Up to 24bit 192kHz / DoP DSD64
Optical : Up to 24bit 192kHz / DoP DSD64
I2S : PCM Up to 32bit 384kHz / DSD256
Inputs1x Coaxial
1x Optical Toslink
I2S
Outputs1x Stereo RCA
1x Jack 3.5mm
AOP (DIP8)1x NJM 5532DD
Filters listFast roll-off minimum
Fast roll-off linear
Slow roll-off linear
Brickwall filter
Power supplyDual : +15V ~150mA, -15V ~10mA
Single : 15V ~150mA (Pour alimenter le module via le Jack DC, effectuer au préalable un point de soudure sur J6)
Dimensions module DAC87 x 76.6
Entraxes module DAC78 x 55mm
Dimensions module Écran75 x 34mm
Entraxes module Écran67 x 24mm
Package1x DAC ES9038Q2M
1x Écran TFT
1x Encodeur Rotatif
2x Nappes d'interconnexion
InputI2S
OutputJack 3.5mm
correct mais il manque une information
Il a fallu que j'aille chercher sur un site de vente chinoix concurrent pour trouver comment faire fonctionner cette carte une fois l'écran connecté :
vous devez mettre un jumper sur J1 et J2 sinon rien ne fonctionne. ceci n'est pas précisé ici.
Merci, nous allons ajouter cette précision à la fiche.
This review has been posted for DAC ES9038Q2M Module I2S Coaxial Optical 32bit 384kHz DSD
This module is equipped with the excellent latest generation DAC ESS ES9038Q2M. This one offers very high flight digital-to-analog conversion...
