ESS ES9038Q2M DAC Module I2S Optical Coaxial 32bit 384khz DSD256
This DIY module based on a DAC I2S ESS ES9038Q2M offers many possibilities of use in a compact card format. It has I2S, SPDIF Coaxial and Optical inputs and RCA Stereo output as well as 3.5mm Jack and supports high resolution files.
4.9 / 5
Reference : 12557
59,90 €tax incl.
49,92 € tax excl.
Module DAC ES9038Q2M I2S Optique Coaxial 32bit 384khz DSD256
This DIY module based on a DAC I2S ESS ES9038Q2M offers many possibilities of use in a compact card format. It has I2S, SPDIF Coaxial and Optical inputs and a RCA Stereo output as well as a 3.5mm jack. On the component side, this DAC module includes a 100MHz master clock making it compatible with many DSP cards on the market. Among the options available, it is possible to change the original AOP 5532D mounted on a DIP8 bracket to adapt the sound reproduction of the DAC to its listening.
The coaxial input requires the source signal to be at least 1.2V
Modular power supply section
A good DAC must be powered by a quality power supply. The module is delivered configured to work with a simple AC adapter or a conventional 15V DC linear power supply, to be connected to a 5.5/2...5mm jack connector. It is also possible to power this DAC via the +15/0/-15V DC balanced input. To do this, it is necessary to solder between the central contact and the left contact of J6, and to unsolder the right contact.
Configurable digital filters & integrated controls
Thanks to its 100MHz digital master clock, it is sufficient to input an I2S DATA, LRCK and BCLK signal from a USB to I2S interface, for example, to obtain a DAC of a formidable quality. This DAC also has Coaxial and Optical SPDIF inputs that can be configured via the module's DIP Switch..
In addition, the module includes 3 control buttons. The VOL + and VOL - buttons are used to adjust the volume. It is also possible to add an external potentiometer on this module (sold separately). A short press of the MODE button switches to Mute mode and a long press of the same button selects the active input. LEDs on the card indicate the active input.
Digital filter selection
FilterDIP 1DIP 2DIP 3
Fast roll-off minimumOOO
XXX
Slow roll-off minimumOXX
Fast roll-off linearXOX
Slow roll-off linearOOX
Brickwall filterXXO
Hybrid dast roll-offOXO
Apodizing fast roll-offXOO
Volume configuration
Volume settingDIP 4DIP 5Note
No volume memoryOOVolume at 70% when power on
Volume memoryXXUse the same volume settings as at power-off
Volume control with potentiometerOXVolume setting by the potentiometer voltage
XO
Module DAC ESS ES9038Q2M I2S Optique Coaxial 32bit 384kHz DSD256
Product typeDAC Module
DAC ChipESS ES9038Q2M
DAC architectureHyperStream
DNR129dB
THD+N-120dB
Supported sampling rateI2S : PCM up to 32bit 384kHz, DSD up to DSD256
Coaxial / Optical : PCM up to 192kHz, DSD up to DSD64
Inputs1x I2S
1x Coaxial
1x Optical
Outputs1x Stereo RC
1x Jack 3.5mm
Dimensions90 x 75 x 22mm
Fixation holes spacing82 x 51mm
Power supply15V DC on Jack DC 5.5/2.1mm / -15/0/+15V DC (power supply sold separately)
Weight42g
Package1x DAC ES9038Q2M Module
InputI2S
OutputJack 3.5mm
DAC / ADC ChipES9038Q2M
Max sampling rateDSD256
Max sampling rate384kHz
Channel2 (Stereo)
8 reviews
Quite nice to build uppon
For its price it is really a no-brainer. Using a few of them and if you are up to it, use muses3 opamps, change the clock and use dedicated cpu's on all sections, removing the onboard regulators.
Then this baby can sing
This review has been posted for ESS ES9038Q2M DAC Module I2S Optical Coaxial 32bit 384khz DSD256
Worked without problems right from the start. The need for unsoldering and re-soldering the 0R SMD "resistor" for using wih a dual power-supply is unconvenient, much better here would be a jumper with two positions.
Sound wise (until now I only used the optical in) already great, really met my expectations. Output stage with elco's in signal path leaves room for individual improvements.
I'm very satisfied
The circuit board is well and cleanly made.
I bought them for the conversion -
Power supply -
3X LT 3045
3X LT 1963
and I / V output -
3X LM 49720
I'm very satisfied
Power supply -
3X LT 3045
3X LT 1963
and I / V output -
3X LM 49720
I'm very satisfied
Power supply -
3X LT 3045
3X LT 1963
and I / V output -
3X LM 49720
This DIY module based on a DAC I2S ESS ES9038Q2M offers many possibilities of use in a compact card format. It has I2S, SPDIF Coaxial and Optical...
