KHADAS TONE BOARD GENERIC EDITION ES9038Q2M DAC Module USB XMOS U208 SPDIF 32bit 768kHz DSD256
4.8 / 5
Reference : 13062
105,00 €tax incl.
87,50 € tax excl.
This product has been replaced by the new version, the KHADAS TONE2 PRO DAC.
This is Tone Board GENERIC EDITION, designed for great versatility and large integration potential. If you plan to use your Tone Board with a VIM Board, the VIM version of Khadas ToneBoard will suit you more.
Khadas DAC Tone Board Module
ES9038Q2M XMOS U208 DSD256 PCM768kHz / 32bit SPDIF
Khadas Toneboard DAC Es9038
DAC ESS Sabre ES9038Q2M
Tone Board uses a decoding chip ES9038Q2M. Not only is it ESS flagship product, but it is also one of today's best solutions for high-fidelity audio decoding.
It embeds famous HyperStream 32 BIT 768kHz architecture and DSD256 support. Advanced reconstruction filters and excellent finesse in dithering complete the picture.
This component is at the heart of the device. It promotes accurate audio reproduction with sustained momentum and a wider soundstage. This takes advantage of excellent performance such as > 120dB  SNR,  very low harmonic distortion (0.000337% @ 1kHz) and significantly low jitter (< 3ps clock jitter.)
XMOS USB U208
XMOS chip U208
The ToneBoard connects directly to a USB source through XMOS interface U208 (8 cores). This type of interface is among the best existing solutions to stream audio through USB.
This USB chip natively supports DSD, that is to say the source provided the DAC recognize this protocol as a standard audio and will not impose any additional conversion step that may alter the quality of the digital signal.
USB-C / SPDIF / RCA
USB DAC-C RCA SPDIF
The ToneBoard has a S / PDIF port configured by default as input. It may nevertheless be configured output depending on the particular needs of each installation.
As part of this DAC module, the USB interface is already connected to a USB-C connector type, which means that this product is completely up to date on this connection and will operate without adapter with most of the upcoming devices (PC, Smartphone, Tablet, Audio Players, DAP ... etc.)
Finally, the analog stereo RCA output is on high quality gold plated terminals.
Note: The Coaxial S/PDIF input can only be used as an input if no computer or device is connected via USB (the switch is automatic).
Formidable audio performance
Component selection and integration, quality connectors, high quality  PCB manufacturing, Khadas made no compromise on audio quality.
The device also takes advantage of two clocks with ultra-low noise quartz and very low phase noise.
The power stage operates thanks to low dropout regulators as a way to limit unwanted noise while retaining a very accessible power system.
Extremely intuitive integration
Connection TONEBOARD pc headphone amp
In its most basicss functions, simply connect the card to a computer or an audio source via USB plug-C for a functional system.
The device is compatible with Windows, Linux, MacOS. Windows, however, requires a driver (see download tab on this page).
Software Solutions & Stand-alone.
Volumio digital audiophile player
With its XMOS interface, ToneBoard is natively recognized by Volumio and can be configured as direct audio output in the software solution.
For advanced users, it is also possible to configure Raspbian directly to drive the card.
By default, the port S/PDIF is configured as an input and allows direct connection without any configuration up to 192kHz
Test Audio Science Review
KHADAS has been the subject of a detailed comparative analysis by the Audio Science Review platform.
Click here to access the Khadas review.
The Tone Board only works with a Raspberry Pi via USB, not I2S.
Parts supplied
Generic Edition Tone Board x1
USB-C Male to USB-A Male cablex1
Screws and PCB Mounting setx1
40 PIN connector femalex1
20 PIN connectorx1
Characteristics
TypeDAC / interface USB
VersionGeneric Edition
Interface USBXMOS XU208-128-QF48 (8 cores 500 MIPS)
DACES9038Q2M 32b
THD+N≤ 0.000337% @1KHz
SNR≥ 120dB @ 10Hz~20KHz
Crosstalk≥ 127dB @ 10Hz~20KHz
Frequency response± 0.08 dB @ 10Hz~20KHz
Sampling frequencyUp to 32bit 768kHz @
DSDUp to DSD256
jitter watch< 3 ps
Jitter DATA< 30 ps
Supported audio formatsAPE2/FLAC/OGG/WAV/ACC/ALAC/MP3/WMA
Line OutRCA (White Red)
IndicatorWhite LED
distancesSize M2 x 5
FPC Connectors30-Pin 0.5 mm (Extension 8 channels)
SPDIFUp to 192 kHz
Port USB-CPower supply (5V / 500mA) & USB 2.0 Data
GPIO40 pins & 20 Pins
Dimensions82 x 56 x 17 mm
CompatibleWindows
Linux
macOS
Raspberry Pi (only via USB) / and other compatible SBC GPIO...
Dimensions
Khadas Tone board Dimensions Audiophonics
PINOUT
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Download
Driver_Khadas_Toneboard_windows
Driver required to use Toneboard Khadas with windows
Download (1.93M)
29 reviews
super mini Dac
Un très bon dac , la connectique est limitée mais l'écoute est superbe et c'est bluffant pour un petit truc au rqp imbattable. Voire les revues du Web pour les détails.
This review has been posted for KHADAS TONE BOARD GENERIC EDITION ES9038Q2M DAC Module USB XMOS U208 SPDIF 32bit 768kHz DSD256
fine dac, fast shipping.
exceptionally good DAC for the money and especially if you connect it via a linear power supply.
just a pity that the data lines are not compatible (gpio) with, for example, the raspberry pi.
otherwise an excellent DAC and fast shipping.
excellent produit.
belle musicalité mais pb avec l'entree usb-c
dommage qd je branche le DAC,je suis oblige de le deconnecter et reconnecter pour que le son sorte normalement.Alimenté par alim lsu25 et signal fourni par lecteur cd en entrée spdif.
Top qualité pour un investissement modique !
Afin d'en tirer le maximum mon dac Khadas a sa propre alimentation externe, une allo (Référence : 11638), raccordée aux pins 1 (+) et 21 (-).
Il est installé dans le boîtier proposé par Audiophonic (Référence : 13626), ceci a nécessité de percer la plaque arrière entre les rca et l'usb pour y installer un connecteur d'alimentation.
Il reçoit le signal digital d'une interface digitale ALLO DIGIONE (Référence : 12067)
Une façon élégante et économique d'enterrer la polémique sur la dégradation de la qualité sonore si on passe par l'usb.
Dans Volumio il faut sélectionner I2S et Digione dans les paramètres de lecture, il faut aussi savoir que la commande de volume ne sera plus opérationnelle dans son interface.
Un ensemble musical, discret et accessible.
