On peut changer l'aop de sortie si on le souhaite, il est monté sur support .Les diodes d'indication sont un peu trop lumineuses et pas déportées par contre...
DAC Module CS8416 AK4396 24Bit 192KHz
Here is an excellent and economical DAC module equipped with quality components and ready to be integrated into your DIY projects. It is based on proven components, a Cirrus Logic CS4816 chip for SPDIF reception and an AKM AK4396 digital/analogue converter.
This compact DAC card can convert digital signals up to PCM 24bit 192kHz.
To operate it requires a 30VA transformer with these voltages: 2x15V AC + 1x9V AC. The 15V AC is used for the analog part and the 9V AC for the digital part.
Product type | DAC Module |
SPDIF Reception chip | Cirrus Logic CS8416 |
DAC Chip | AKM AK4396 |
Output OPA | NE5532P (on DIP8 support) |
Input | 1x Coaxial on screw terminal |
Output | Analog on screw terminal |
Status LED | Power : powered module 96K : reception of a signal higher than 88.2kHz Error : signal unlocking No Audio : no signal |
Power supply | 30VA 2x15VAC + 1x9VAC |
Dimensions | 80 x 80 x 35mm |
Mounting holes spacing | 75mm |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Xavier D.
