DIY Box / Case 100% Aluminium 260x311x90mm Black pannel
This aluminum-grade case with a thick 8mm faceplate is perfect for designing class D preamplifiers, DACs or power amplifiers for a professional quality finish. This box comes with all the necessary hardware, the IEC socket and 4 anti slip feet.
Reference : 14211
75,00 €tax incl.
62,50 € tax excl.
DIY 100% Aluminum housing 260x311x90mm
This beautifully made 100% Aluminum DIY case is perfect for designing High-End DAC or class D amplifiers.
Its original design ensures a professional fit and finish. It is also particularly suitable for the design of preamplifiers and audiophile power supplies.
Height and thickness of the panels
thumbs%20COTATION%20EXTERNE%20ET%20INTER
Internal / external width + length
IEC DImensions
Utilie width (internal)220mm
Effective depth (internal)295mm
Height (internal)77mm
Width (outer)260mm
Depth (External)311mm
Height (external)90mm
Facade anodized aluminum thickness:8mm
back cover thickness:3mm
weight:2.52Kg
Delivered with :Screws, base IEC with fuse holder and 4 feet anti slip.
MaterialAluminium
Internal width220
Internal depth295
Internal height77
This aluminum-grade case with a thick 8mm faceplate is perfect for designing class D preamplifiers, DACs or power amplifiers for a professional...
