Thermal silicone glue ST922 for radiator 5g
The thermal glue type ST922 offers real efficiency for power transistors or dedicated audio controllers. Offering a thermal conduction of 0.671 W/m-k, it will find its place in all DIY projects.
4.0 / 5
Reference : 12564
1,90 €tax incl.
1,58 € tax excl.
THERMAL SILICONE GLUE ST922 TYPE
This thermal adhesive is ideal for the fastening of transistors, regulators requiring effective insulation. This glue, which is coated with silicone, makes an excellent thermal seal between radiators and active components. It is recommended for the mounting of amplifiers, power supplies Do It Yourself.
Technical caractheristics :
  • Thermal silicone adhesive for active component
  • thermal conductivity: > 0.671 W/m-k
  • thermal resistance: < 0.06 °C-in2/W
  • Colour of glue: white
  • Tensile strength: 1.5MPA
  • Tube dimensions: 55 x 18mm
  • Weight: 8g
ColorN/A
MaterialSilicon
Internal widthN/A
Internal depthN/A
Internal heightN/A
2 reviews
Recommandé
Pratique ; transmet bien la chaleur et cimente bient les éléments.
Donc parfait !
This review has been posted for Thermal silicone glue ST922 for radiator 5g
Produit conforme, c'est bien une colle
Par contre, elle sèche très vite dans le tube ... même bien rebouché !
Il faut à chaque usage différent déboucher le tube pour enlever la partie durcie de la colle qui en empêche l'utilisation normale !
The thermal glue type ST922 offers real efficiency for power transistors or dedicated audio controllers. Offering a thermal conduction of 0.671...
