This CS8421 module with I2S inputs and outputs allows to lower the jittersignificantly with a theoretical dynamic of 175 dB. Thanks to its ASRC process this module is very efficient. It is a TI SRC 4192.
It generates a Masterclock in output I2S thanks to its clock of 27Mhz. So this module will be very useful for devices not coming out of Masterclock (MCLK / WCLK).
The qualities of ASRC modulesare known to lower the background noise, jitter and increase the readability of microphone information
Attention: The clock generated at the output is 211Khz. It will be necessary to check if your incoming I2S module (DAC, DSP) is compatible.
An explanatory PDF in the download tab is available.
Module features:
I2S outputs:
Dimensions / Weight:
