Balanced to Unbalanced Converter Module SSM2141 NE5534P
This module converts a stereo balanced signal into a stereo unbalanced signal. The input and output connections are simply made on screw terminals. To carry out this conversion, the module uses on each channel a differential amplifier SSM2151 and an operational amplifier NE5534P in order to effectively limit the generated noise.
Reference : 14306
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 31-01-2025.
SSM2141 NE5534P
Module désymétriseur SSM2141 NE5534P
This module converts a stereo balanced signal into a stereo unbalanced signal. The input and output connections are simply made on screw terminals. To carry out this conversion, the module uses on each channel a differential amplifier SSM2151 and an operational amplifier NE5534P in order to effectively limit the generated noise. The internal resistances of the SSM2141 are laser adjusted to a precision tolerance of 0.0001%. Their performance in terms of noise, distortion and interference is therefore close to professional level.
Spacings
Product typeBalanced to unbalanced converter module
Inputs2x Mono balanced inputs
Sortie1x Stereo unbalanced output
Power supply (not included)+12V - 0 - -12V
Dimensions86.6 x 49.5 x 16mm
Weight40g
InputScrew terminals
OutputScrew terminals
Max sampling rateNC
Channel2 (Stereo)
Interface chipSSM2141
This module converts a stereo balanced signal into a stereo unbalanced signal. The input and output connections are simply made on screw terminals....
