Balanced to Unbalanced Converter XLR / RCA (Pair)
This pair of modules converts a balanced signal on XLR input to an unbalanced signal on XH 2.54mm output. A second input is also available in RCA format, with a switch to simply select the active input.
Reference : 14305
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 03-04-2025.
Module interface désymétriseur XLR RCA (La paire)
This pair of modules converts a balanced signal on XLR input to an unbalanced signal on XH 2.54mm output. A second input is also available in RCA format, with a switch to simply select the active input. A differential amplifier and an operational amplifier efficiently process the input signals in order to limit the generated noise. The internal resistance of the SSM2141 is laser adjusted to a precision tolerance of 0.0001%. Its performance in terms of noise, distortion and interference is close to professional level.
Module overview
Module overview
1RCA input
2Input selector
3XLR input
4AC power supply 12V-0-12V
5Unbalanced output
Product typeBalanced to unbalanced converter
Inputs1x XLR
1x RCA
Output1x XH 2.54mm 2 pins
Power supply (not included)AC 15V-0-15V
Dimensions (one module)102 x 40mm
Weight (one module)65g
Cable includedXH 2-pole to bare wires
InputXLR
OutputXH 2.54mm
Max sampling rateNC
Interface chipSSM2141
This pair of modules converts a balanced signal on XLR input to an unbalanced signal on XH 2.54mm output. A second input is also available in RCA...
