Digital Interface USB to I2S ARM CPLD 32bit 384kHz DSD512
This high quality USB to I2S interface module allows you to get an I2S/DSD output from a USB computer source. Associated with a DAC with I2S input, it allows you to create a complete product that can be read from a PC, Mac or Linux source.
Reference : 15160
59,90 €tax incl.
49,92 € tax excl.
Digital Interface
Digital Interface USB I2S
This high quality USB to I2S interface module allows you to get an I2S/DSD output from a USB computer source. Associated with a DAC with I2S input, it allows you to create a complete product that can be read from a PC, Mac or Linux source. It works with an ARM Cortex M3 ATSAM3U processor and processes the signals using a XILINX CPLD model XC2C64A. These use two low phase noise TCXO clocks 24.5760 & 22.5792Mhz. This allows the module to interface high sample rates (up to 384Khz / DSD512) with low jitter.
Product typeDigital interface
ChipsetARM® Cortex®-M3 ATSAM3U
CPLD XILINX® XC2C64A
Clocks2x TCXO
InputUSB-B
OutputI2S
Supported sampling rates
PCM up to 32bit 384kHz
DSD up to DSD512
Output formatI2S 32bit or DSD64,DSD128 - and Native DSD256,DSD512 under windows
SupportNo drivers required
Windows systemsKS / Wasapi / WDM/ASIO
PCB Dimensioons30x69 mm
OutputI2S
Max sampling rate384kHz
Max sampling rateDSD512
Interface chipNC
This high quality USB to I2S interface module allows you to get an I2S/DSD output from a USB computer source. Associated with a DAC with I2S input,...
