Digitale Interface I2S vers SPDIF BNC WM8805 24bit 192kHz
This WM8805 interface with DSP XilinX allows you to transform an I2S signal with MCLK to a classic SPDIF signal on a 75 Ohm BNC connector.
4.5 / 5
Reference : 12561
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 13-02-2025.
interface digitale Wm8805
Digital interface I2S to SPDIF
Interface numérique I2S vers SPDIF BNC WM8805 24bit 192kHz
This I2s to SPDIF interface allows for example to transform an I2S signal coming from a DSP card, a digital source or an audio CD player. Thanks to its Wm8804 receiver interface, it produces a very low jitter.
For the management of the Masterclock MCLK it is necessary to either solder a compatible full size clock or to input an external MCLK through the I2S input. It also has a TTL SPDIF output at 2.7V.
It requires a 5V DC power supply to operate, for example  : DC LT1084 2.5V to 35V 5A.
Compatible clock frequency :
192Khz : 24.576mhz
176.4Khz : 22.5792Mhz
96Khz : 24.576Mhz
88.2Khz : 22.5792Mhz
48Khz : 12.288mhz
44.1Khz : 11.2896Mhz
1TTL output, bypass the Pulse transformer
2SPDIF output
3I2S input
45VDC power supply
5Full size clock slot
1Solder M1 and M2 for internal MCK clock
Desolder M1 and M2 for external MCK clock
Connectors
Inputs1x I2S
Outputs1x SPDIF
1x I2S
Components
RegulatorX1
Digital interface receiverWM8805
75 Ohm transformerPulse PE65612NL
Supply voltage5V DC (power supply sold separately) on screw terminals
InputI2S
OutputI2S
OutputCoaxial SPDIF
Max sampling rateNC
Interface chipWM8805
2 reviews
Great sound quality
I2S to SPDIF without problems.
In my high quality set up, this board proved to be very good, feeded with Jung super regulator power supply.
Be aware that you need the MCLK connection of I2S (or buy a clock to solder on this board). On the board this is a seperately placed pin, labeled MCL.
This review has been posted for Digitale Interface I2S vers SPDIF BNC WM8805 24bit 192kHz
it works well
It works, if you want to connect to rca SPDIF (not BNC) connect sign(-) from (spdif out) to ground of rca cable, sign(+) throught a 75 ohm resistor in series to central pin of RCA cable . (without resistor conection jumps random) try any value near 75 ohm, mine 100 ohm works well.
