HDMI to I2S / SPDIF Digital Interface
This interface module allows you to extract an audio signal from HDMI to output directly to I2S or SPDIF. The I2S is capable of supporting high resolution DSD files as well as DTS or AC3.
Reference : 13415
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 22-04-2025.
Digital Interface HDMI to I2S / SPDIF
Interface Digitale I2S LVDS HDMI vers I2S / SPDIF
This interface module allows you to extract an audio signal from HDMI to output directly to I2S or SPDIF. The I2S is capable of supporting high resolution DSD files as well as DTS or AC3. For its power supply, the interface can either take advantage of the power supply of the module associated with it (if the latter allows it) or be powered via a dedicated 5V DC power supply.
Warning: this module does not extract SPDIF from a digital output of a standard HDMI port.
Wiring cable
Product typeHDMI to I2S / SPDIF interface
InputHDMI
OutputsI2S
SPDIF
Supply voltage5V DC (power supply not included)
Dimensions50 x 52mm
Package1x HDMI / I2S Interface module
1x 9 wires flat cable
InputHDMI
OutputI2S
Max sampling rateNC
Interface chipNC
This interface module allows you to extract an audio signal from HDMI to output directly to I2S or SPDIF. The I2S is capable of supporting high...
