Interface Extractor Module HDMI to HDMI I2S / SPDIF
This interface module allows you to extract and split the signal from the HDMI input. This can then be output in HDMI, I2S or S/PDIF. HDMI input and output is done on mounted connectors. The I2S and S/PDIF outputs are to be wired to the contact points provided for this purpose. HDMI input and output support video streams up to 2K.
Product type | HDMI Interface |
Input | 1x HDMI |
Outputs | 1x HDMI 1x I2S 1x S/PDIF |
Max. supported HDMI video resolution | 2K |
Power supply | 5V DC (power supply sold separately) |
Dimensions | 70 x 70mm |
Fixation holes spacing | 63 x 42mm |
