This X10-I2S module will allow you to enjoy a USB interface to I2S, Coaxial and Optics in a very simple way. So you can upgrade your DIY audio system based, for example, on a Raspberry Pi and offer it new possibilities.
BRAVO SA9227 Interface to I2S / Coaxial SPDIF / Optical 32bit 384kHz DSD
The X10-I2S module allows it user to enjoy a USB interface to I2S, Coaxial and Optical in a very simple way. It is very useful when it comes to upgrade any DIY audio system based for example on a Raspberry Pi to provide new possibilities.
List of modules of the X10 and X20 series sold separately:
This USB interface is based on a chip BRAVO Audio SA9227. This component has excellent audio capabilities and can handle seamlessly digital audio streams up to 384kHz 16/24/32 bit (PCM). The 1-bit formats are not left behind with a DSD64 / DSD 128 support.
The SA9227 interface is first designed to be used directly with a SBC Raspberry Pi.
It can also operate in standalone mode, a solution that allows changing the DAC Module quickly and effortlessly for benchmarking hardware or to favor a specific speaker / amp technology when listenning.
This solution is therefore as good as practical and economical.
This interface offers your system a more complete connectivity. Thus, as input we will find a USB-A 2.0 port supported by an SA9297 chip. The interface also comes with a small USB loopback extension, making it easy to connect this X10-I2S to another module.
Caution : the port layout on a Raspberry Pi 4 does not fit with this extension. Use a USB-A to USB-A male cable instead.
On the output side, the module offers SPDIF (Coaxial), Toslink Optics and I2S for optimal sound quality.
The interface also incorporates an ultra-low phase jitter SiTime SiT8208 SiTime oscillator, a Pulse PE-6561NL digital signal transformer with a design to limit EMI noise and interference, and an ultra-low noise voltage regulator from Texas Instruments for optimal operation.
USB interface | XMOS |
Sampling rates supported | USB : PCM up to 32bit 384kHz / up to DSD128 Native SPDIF : PCM up to 24bit 192kHz |
Supported OS | Volumio, Moode Audio PLayer, Windows, Android... |
Oscillator | SiTime SiT8208 |
Digital signal transformer | Pulse PE-6561NL |
Voltage Regulator | Texas Instruments Ultra-Low Noise Voltage Regulator |
DSD | Native, DoP64, DoP128 |
Power supply | 5V DC ±5% |
Dimensions | 85 x 56 x 15mm |
Fixation holes distances | 58 x 49mm |
Accessories | USB extension board Screws and spacers |
The announced sampling rates are only valid on the I2S output. They are therefore not valid for use with an X10-DAC / X20-DAC. With the latter, the sampling rates in PCM go up to 24bit 192kHz.
The X10-I2S interface is compatible with Volumio. To be able to use these two solutions together, a simple manipulation is necessary.
