No problems at all. The I2S input from this device gave an improvement on the sound quality from my DSP, compared to my previous SPDIF input. Recommended!
USB to I2S Interface XMOS XU208 32bit 384kHz DSD256
This USB to I2S digital interface includes an XMOS XU208 chip supporting high sampling rates up to 32bit PCM 384kHz and DSD256.
Its XU208 chip offers significant power allowing fast and efficient data processing for the minimum latency required for bit-perfect reading. It is accompanied by 3 separate clocks precisely respecting each multiple of 44.1kHz and 48kHz from 16 to 32bit but also by an ultra-low noise voltage regulator ADP150 and MLCC decoupling capacitors for precise and clear reproduction.
Offering very good design quality at a very affordable price, this interface is ideal for DIY integration into a DAC.
44.1 | 48 | 88.2 | 96 | 176 | 192 | 352 | 384 | DSD64 | DSD128 | DSD256 | |
F0 | 0 | 1 | 0 | 1 | 0 | 1 | 0 | 1 | 0 | 0 | 0 |
F1 | 0 | 0 | 1 | 1 | 0 | 0 | 1 | 1 | 1 | 0 | 1 |
F2 | 0 | 0 | 0 | 0 | 1 | 1 | 1 | 1 | 0 | 1 | 1 |
DSD ON | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | 1 | 1 |
Product type | USB Interface |
USB interface chip | XMOS U208 |
Input | 1x USB-B |
Output | I2S |
Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 |
Dimensions | 69 x 30.5 x 15mm |
Distance between fixation holes | 63.5 x 25mm |
Input | USB |
Output | I2S |
Output | S/PDIF |
Max sampling rate | 384kHz |
Max sampling rate | DSD256 |
Interface chip | XMOS XCore U208 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
