USB-B to I2S SPDIF DSD512
This XMOS U208 card is the latest generation of high quality USB to SPDIF / I2S interfaces, opening the door to high fidelity audio. With two separate watches of 22.5792Mhz and 24.576Mhz and an Altera Max II CPLD regenerating the output signals of the XMOS, the module provides a very low jitter for a more accurate sound. In addition, it supported by the sampling rate up to 32bit 384kHz but also the DSD512 to satisfy the most audiophile.
You will find the necessary driver in the "Download" tab of this page.
Chip model | XMOS U208 |
CPLD | Altera Max II |
Input | USB-B |
Output | SPDIF (I2S) |
Bitrate | PCM 32bit 384kHz DSD512 |
Input | USB |
Output | I2S |
Max sampling rate | DSD512 |
Max sampling rate | 384kHz |
Interface chip | XMOS XCore U208 |
