XMOS U208 Digital Interface USB to I2S / SPDIF 32bit/384khz
This latest generation XMOS XU208 USB to I2S interface supports sampling rates up to 32bit 384kHz and is compatible with DXD and DSD64-256 (2.8MHz-11.2MHz). It will allow you to enjoy high definition on a 24 or 32 bit audio DAC with I2S input.
Reference : 12189
42,90 €tax incl.
35,75 € tax excl.
USB Interface
Interface USB XMOS U208 vers I2S / SPDIF 32bit 384kHz DSD256
Its XU208 1000Mips chip replaces the old U8 500Mips generation. It has 8 times the computing power of its little sister. Equipped with additional refinements such as superior noise insulation, it is also more stable in voltage with an LDO regulator. It has three separate clocks that accurately respect each multiple of 44.1kHz and 48kHz from 16 to 32bit.
This XMOS U208 interface is therefore particularly attractive due to its components and technology with an excellent quality ratio for all 32bit 384kHz DIY DACs.
It is compatible with our DAC I2S PCM5102, I2S PCM ES9023, AK4495SEQ (see accessories).
Product typeUSB Interface
USB Interface chipXMOS XU208
Supported sampling ratePCM : I2S up to 32bit 384kHz, SPDID up to 24bit 192kHz
DSD : I2S up to  DSD256, SPDIF up to DSD64 DoP
OutputI2S
SPDIF (requires soldering)
InputUSB-B 2.0
CompatibilityMac OS, Linux, Windows (XMOS driver needed)
Dimensions74 x 34.3 x 12.5mm
Fixation holes spacing63 x 25mm
Max sampling rate384kHz
Max sampling rateDSD256
Interface chipXMOS XCore U208
2 reviews
excellent produit
Résultats excellents en pcm comme en dsd, supérieurs au module LJ CM que je possède aussi.
J'ai eu un souci avec le DSD qui ne passait pas. Audiophonics a oublié d'indiquer le driver à charger pour windows. Problème réglé avec le SAV.
Pour son prix, ce module est étonnant.
Je le recommande fortement.
Pierre
This review has been posted for XMOS U208 Digital Interface USB to I2S / SPDIF 32bit/384khz
Elle fait la différence!
testée en remplacement d'une LJ CM6631A pour accompagner un module ESS ES9038Q2M, dès la première écoute une perception beaucoup plus fine des détail, beaucoup d'espace et une meilleure représentation spatiale.
A noter, les amplis op du module ES9038Q2M avaient été remplacés par des Muses03.
This latest generation XMOS XU208 USB to I2S interface supports sampling rates up to 32bit 384kHz and is compatible with DXD and DSD64-256...
