This latest generation XU208 board allows the design of high-quality USB to SPDIF (Toslink and I2S) interfaces. Featuring two separate SCTF clocks 22.5792mhz and 24.576mhzcompatible DSD 64/128 native, the amateur audiophile will be filled by the versatility of this interface integrating a component XMOS X U208of 1000 Mips.
With resolution and processing twice as much as a classic UM XMOS U8 it has an I2S output that can climb to DSD DOP 256 compatible ASIO for Wndows. Naked, the Do-It-Yourself lover will be able to weld the SPDIF connector of his choice as well RCA as BNC 75ohm. The printed circuit board has full-size clock slots. The experienced handyman will be able to weld for example TCXO clocks of high precision.
This USB X U208 interface has a separate input for the 5V voltage on 5.5 / 2.5 jack. With a linear quality feed the sound will be even better lowering the jitter avoiding the noise of the 5V voltages provided by the USB of a computer.
(DSD and POWER status LED not supplied, TOSLINK connector not supplied)
Characteristics :
I2S Broaching:
