XMOS U8 Digital interface USB to SPDIF 32bit/384khz / Pre-welded pines
Reference : 10957
29,90 €tax incl.
24,92 € tax excl.
This Xmos module U8is an interfaceUSBtowardsI2S or SPDIF. With a maximum resolution of 32 bit 384KhzDXD compatible andDSD64 ~ 256 (2.8Mhz ~ 12.88Mhz), this interface opens the doors of high definition on any DAC audio 24 and 32 bit with I2S input.
It is compatible with our CADI2S PCM5102,I2S PCM ES9023,AK4495SEQ.
A Windows ASIO driveris available in the download tab on the right of this page.
Specifications:
  • XMOS Module U8
  • Maximum Supported Sampling Rate I2S: 32Bit 384kHz
  • Maximum Supported Sampling Rate SPDIF: 24Bit 192kHz
  • DSD 64 ~ 256. (2.8Mhz up to 12.88Mhz)
  • I2S digital output
  • SPDIF output (requires RCA connector not included)
Dimensions and weight:
  • PCB Dimensions: 32 x 69mm
  • Spacing: 25 x 61mm
  • Weight: 16g
  • Pre-welded pines!
OutputI2S
Max sampling rate384kHz
Max sampling rateDSD256
Bon rapport Q/prix
Produit simple, peu onéreux et simplement correct. On peut certainement mieux faire mais c'est plus cher....
This review has been posted for XMOS U8 Digital interface USB to SPDIF 32bit/384khz / Pre-welded pines
