AUDIOPHONICS PI-SPC V2 Power Management Module for Raspberry Pi Preassembled
4.0 / 5
Reference : 11125
17,90 €tax incl.
14,92 € tax excl.
This power control module for Raspberry Pi makes it possible to turn on and off its Raspberry Pi cleanly like a family ATX PC.
This version has its pre-welded pins, as well as its pre-mounted USB cable (Micro USB). So no welding is necessary on your part.
This module is perfectly combined with this pre-welded aluminum push button .
Once the monostable switch is switched on, your Linux distribution (Volumio, MoodeAudio, piCore, Rune Audio) starts up like any other family computer. Same for the shutdown function
A power LED output is available to monitor the evolution of the various stages of switching on and off the Raspberry pi.
Main Features :
  • Starter and Extinction management module delivered flashed and ready for use
  • Input power either via connection pins or micro USB
  • Footprint available to put a fuse on the power line
  • Diameter fixing holes: 2,5mm
  • Dimensions: 25x25mm
  • Pins supplied and pre-welded
  • Pre-welded USB cable
Features:
1 - Push Button:
  • Raspberry pi off: Pressing the push buttonwill start the rpi.
  • Raspberry pi on: Press> 0.2 seconds and <4 seconds, Shutdown command sent, the rpi will go off after you stop the software solution used properly.
  • Raspberry pi on: Press> 4 seconds, emergency stop function, immediate power off of the pi (function available at any time)
2 - LED states "Power" (depending on orders sent)
  • Off: Raspberry pi off
  • Slow flashing: Raspberry pi is switched on, start of the software solution (ex: Volumio is being launched), the same for extinction.
  • Fast flash: Reboot order sent from the software solution used (eg Volumio.)
  • Steady on: Raspberry Pi powered on, software solution used (eg Volumio.) Properly started and ready for use.
Connection to a Raspberry Pi 3 (not included)
Wiring Diagram of the Audiophonics Power Control Module
Use in the streamer Audiophonics RaspDIGI </ a> (not included):
Connection example with TDA1387
HY
attention
Belle serigraphie, fonctionnement efficace, mais attention à la soudure ne pas trop surchauffer lors de la connection du + & -
This review has been posted for AUDIOPHONICS PI-SPC V2 Power Management Module for Raspberry Pi Preassembled
