Très satisfait !
Utilisé ici pour alimenter un lecteur réseau livré d’origine avec une petite alimentation à découpage externe.
Progrès très net.
Penser à l'ajout d'un transfo alimentation.
The new model is available here: AUDIOPHONICS PSU S4-HP.
The Audiophonics PSU S3-LP power supply module has been designed to provide a clean power supply to an amplifier or other audio circuit.
It has a potentiometer and jumper to adjust the voltage from 5 to 24V from an AC voltage source of 5 to 22V AC respectively.
Its particularly rigorous design, and the quality of its components, make it an excellent choice for powering a digital amplifier or any other low voltage high-fidelity element such as certain DAC converters, headphone amplifiers, etc...
So many devices for which it contributes to improve the sound quality.
The Audiophonics PSU S3 makes use of 4 fast switching 2CZ2545 A9 diodes.
On the filtering side, 10 Rubycon capacitors of 2200uF/35V with an ESR of 0.0019 Ohm and a current capacity of 3.1A per capacitor.
Once the voltage is stabilised, it is then regulated by means of a LINEAR TECHNOLOGY LT1083, renowned for its low ripple (0.015%).
Features:
Specifications :
| Input | Screw terminals |
| Input | Solder pad |
| Output | Solder pad |
| Output | Screw terminals |
| Output voltage (V) | 24.0 |
| Output voltage (V) | 10.0 |
| Output voltage (V) | 15.0 |
| Output voltage (V) | 5.0 |
| Output voltage (V) | 20.0 |
| Output current (A) | 5.0 |
| Input voltage (V) | N/A |
| Power Supply | Regulated Linear Power Supply |
Average votes 4.3 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Christian B.
William B.
William B.
Mate P.
Herve L.
