AUDIOPHONICS Trigger 5V 230V Slave Power Supply Device
This accessory, made in France in our workshops, makes it easy to add an automatic ignition (trigger) function to your devices that don't have this feature natively.
Reference : 18135
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 15-04-2025.
A USB-A Male to 3.5mm Mono Jack cable for use with this 5V Trigger is available as an accessory.
Remote shutter trigger sector unit 230v 5v
Trigger 5V Power / IEC
This accessory, made in France, in our workshops, makes it easy to add an automatic on/off function (trigger) to devices that do not have this as a native function.
The principle of operation is simple: the housing has an IEC (sector) Input and output . By default, no current flows between the two connectors.
A second input on 3.5mm jack is located on the side of the device. When this input is fed by a 5V DC, it closes the circuit between the IEC input and output, which allows current to pass.
This type of accessory can be used in a variety of fields. In the case of an audio system, it is especially convenient to turn on several devices simultaneously: A master device equipped with a trigger output connected to the 5V trigger may thus control the activation of other remote devices. The same goes for the shutdown.
If your HiFi or Home Cinema set incorporates a 5V trigger output (HC preamplifier, Blu-ray high-end player) connect product on your amplifier input and drive it from the master device to trigger on elements that are connected to it.
Trigger 5V 230V
Product typetrigger receptor on 230V Module
Voltage max5V
Amperage max8A 230V
InputIEC C13 Female
OutputIEC male C14
Rated operating curren33mA @ 5V
Minimum current25mA (0.025A)
Consumption (5V input)0.36W
5V input400 Ohm / 30mA
Dimensions82 x 58 x 28.5 mm
It requires 25mm spacing on right side, 12mm on left side
Weight66g
InputIEC C14
OutputIEC C13
Output voltage (V)230.0
Output current (A)10.0
Input voltage (V)230.0
Power SupplyTrigger
3 reviews
Très bien
Aucune remarque négative, il réagit bien et se comporte comme décrit. Du bon boulot, merci Audiophonics !
This review has been posted for AUDIOPHONICS Trigger 5V 230V Slave Power Supply Device
Parfait
Fonctionne parfaitement avec un cable USB / Jack.
La prise jack sur le coté peut poser un problème si trop proche d'une entrée ou d'une sortie de l'appareil à contrôler. Située à l'arrière, elle éviterait ce problème.
Connecté avec une prise jack-usb, cet adaptateur allume et éteint un amplificateur et permet de ne pas laisser allumer inutilement un transformateur.
Parfait !
This accessory, made in France in our workshops, makes it easy to add an automatic ignition (trigger) function to your devices that don't have...
