DAYTON AUDIO Panel Mount KAB PMV3 for JAB / KAB
Pre-drilled control panel for KAB / JAB. No welding needed. Comes with all the cables / elements required to enjoy all your JAB / KAB amplification module functions. Professional rendering and easy to assemble.
Reference : 13585
26,90 €tax incl.
22,42 € tax excl.
Last items in stock !
Shipping date: 24-04-2025.
DAYTON Audio - KAB-PMV3
front panel for amplification module JAB / KAB
PMV3 KAB JAB Dayton Audio
A simplified approach for JAB modules
This control panel is a simple and affordable solution for a clean assembly of your amplifiers JAB-based module.
This solution greatly facilitates the integration while saving time on the design of a facade with component integration elements.
Each element, LED, potentiometer, connector is made to be attached to the panel by mechanical means. It is therefore not necessary to use soldering to install the control panel.
The back of the control panel provides enough space to effectively manage cables without hindering the final installation.
Gasket Tape are provided to allow a clean, neat and quick assembly.
KAB Dayton audio panel diy face
Mounting Accessories JAB Wondom KAB Dayton Audio
Compatible with all JAB functions
As evidenced by the many accessories provided, this control plate is designed to exploit all the features found on the JAB / KAB modules.
At the top, there is a display consisting of three LEDs dedicated to the indicate activity. They provide information regarding the status of the following functions: Power On / Off Indicator - Bluetooth activation Indicator - Battery charge indicator.
A rotary potentiometer (delivered with its button) cis in charge of controling the volume. There is also a Bluetooth pairing button and the Aux about 3.5mm connector
Finally, a DC input jack 5.5x2.1mm and the power button on / off complete the panel.
A professional finish to your projects
The plate has markings for the different elements and indicators on your amplifier module JAB / KAB. This greatly contributes to the intelligibility of the device and makes it usable by begginers, once mounted.
Mounting holes are pre-drilled to save time on installation. The supplied screws are wood screws to ensure secure fit while providing maximum freedom of choice for housing materials.
The supplied cables have a very generous length, contributing to an easy final assembly. This kind of detail allows the user to work comfortably without being limited by the cable layout.
Climb its own amplifier easily
TypeMounting panel
volume potentiometerYes
LEDsPower
Bluetooth
Charging state
ColorsBlack
Materialsanodized aluminum
Mounting Holesx4
Dimensions120 x 95 x2.3mm
Package Contents
Screws m3 x 6mm (black)x4
Screws m3 x 6mm (silver)x4
Holding rods m3 x 60mmx4
Mounting screws m3 x16mm (black)x8
Indicator red LED + cable and mounting nutx1
Blue indicator LED + cable and mounting nutx1
Indicator green LED + cable and mounting nutx1
Rotary potentiometer + cable and mounting nutx1
push button / + cable sweater and mounting nutx1
3.5mm stereo jack connector + cable and mounting nutx1
DC jack connector 5.5mm x 2.1 + cable and mounting nutx1
On/OFF Switch + cable and mounting nut x1
Gasket Tape 115 x10mmx2
Gasket Tape 88x10mmx2
InputJack 3.5mm
OutputPCB Connector
OutputNC
ChannelN/A
ClassN/A
Amplifier chipN/A
Power (W)N/A
2 reviews
Très pratique
J'ai acheté ce produit afin d'avoir une finition parfaite pour des petites enceintes diy. Je ne suis pas déçu du produit, bien au contraire, il est très pratique lorsqu'il est installé avec un produit Wondom comme celui que j'avais commandé et la finition est vraiment top !
Excellent rapport qualité/prix, je le recommande sans réserve.
This review has been posted for DAYTON AUDIO Panel Mount KAB PMV3 for JAB / KAB
Très pratique
Il s’agit d’un excellent produit. Tres pratique pour créer des installations bluetooth notamment à partir de vieilles radio TSF. Faciles à monter, même si une notice explicative aurait été nécessaire (ne serait-ce qu’un pdf en ligne).
Bravo pour la disponibilité et rapidité de l’équipe Audiophonics.
Pre-drilled control panel for KAB / JAB. No welding needed. Comes with all the cables / elements required to enjoy all your JAB / KAB amplification...
