HYPEX NILAI500DIY Amplifier Kit Mono Class D 1x525W 4 Ohm
This kit, based on a Nilai500DIY amplifier module and a PS500DIY power supply board, will enable you to design your own 525W (under 4Ω) mono Class D amplifier. As the successor to the NC400, the Nilai500DIY incorporates a completely new control loop topology, taking its performance to a whole new level, for faithful, rich sound reproduction. The whole system ensures very low levels of distortion and noise, favoring pure audio reproduction.
By buying this product you get 99 loyalty points
Reference : 18262
999,00 €tax incl.
832,50 € tax excl.
Shipping date: 22-04-2025.
Grantie 5 ans
Hypex Nilai500DIY Kit
Nilai500DIY Kit Amplificateur Mono Class D 525W 4Ω
It also features a fully discrete buffer stage and integrated voltage regulators. Combined with carefully selected high-quality components, the Nilai500DIY is an exceptional amplification solution, perfectly complemented by the PS500DIY power stage.
The kit includes an easy-to-fit assembly guide, enabling you to assemble this high-end power amplifier yourself. Only a few tools are required: wire cutters, 5.5mm and 7mm open-end wrenches and a 3.5mm flathead screwdriver.
Mounting guide
Product typeMono power amplifier
Amplification typeClass D
Channels1 (Mono)
Amplification moduleNilai500DIY
Input1* XLR
OutputSpeaker terminals
Trigger12V
Output power500W @ 2Ω, 1% THD
525W @ 4Ω, 1% THD
260W @ 8Ω, 1% THD
Input sensitivityLow gain: 12Vrms
Mid gain: 3.8Vrms
High gain: 1.9Vrms
Distortion0.0005% @ 20Hz < f < 20kHz, 4Ω, P < 100W
Input impedance100kΩ
Output impedance90µΩ f < 1kHz
85µΩ f < 20kHz
Supply voltage100-240VAC
Package1* Nilai500DIY board
Wiring cables
1* PS500DIY power supply module
1* Aluminum enclosure
Control boards
Connectors
Feet
Screws
InputXLR
Channel1 (Mono)
Amplifier chipHypex Nilai500DIY
Power (W)525.0
Hypex Nilai 500 DIY kit - Blocs Mono en Classe D
J'ai commandé 2 kits pour amplifier une paire d'enceintes colonne françaises (des Kelinac 714 MG pour ne pas les citer).
La livraison s'est faite dans le délai prévu.
Mon choix s'est porté sur ces kits pour profiter des connexions natives XLR du module d'amplification Nilai 500.
Le montage est relativement facile, la notice est très claire et bien détaillée.
Le châssis est de bonne facture, je ne m'attendais pas à ce qu'il soit aussi épais.
En prenant tout mon temps, il m'a fallu une heure de montage par bloc.
Impression générale d'écoute après trois semaines, ce sont des modules qui proposent une écoute très naturelle,
aucune emphase ni dans le grave ni dans le médium comme on peut en rencontrer (et même apprécier) avec nombre d'amplificateurs à transistors ou lampes.
Sur les chants, la diction est claire sans aucun voile.
Sur les timbres d'instrument, rien à redire, pas d'appauvrissement ni d'embellissement artificiel.
Sur de l'orchestral, la scène sonore tant en profondeur qu'en largeur est parfaitement en place.
Graves sous contrôle absolu, ce qui évite en montant le volume une saturation précoce dans une petite pièce.
A noter au niveau du gain : le gain maximal correspond à une sensibilité d'entrée de 1,9 Vrms (valeur maximale)
A noter au niveau montage : il y'a des vis identifiées MS-3 dans la notice (noires 3x6 avec têtes fraisées) servant à fixer le socle de l'alimentation et le module d'amplification à l'épaisse plaque inférieure,
j'ai eu une des vis qui était un peu juste pour atteindre un des pas de vis du socle de l'alimentation, pas de problème pour fixer le module d'amplification.
Par précaution, pour la fixation du socle de l'alimentation j'ai remplacé par des vis 3x10 (c'est que j'ai trouvé en magasin, des 3x8 auraient convenu, attention des 3x12 sont trop longues) avec têtes fraisées.
This review has been posted for HYPEX NILAI500DIY Amplifier Kit Mono Class D 1x525W 4 Ohm
This kit, based on a Nilai500DIY amplifier module and a PS500DIY power supply board, will enable you to design your own 525W (under 4Ω)...
