Class D Power Amplifier Module 700W
The Hypex UCD700HG-HxR module is a Class D power amplifier, capable of delivering 700W and which will be able to adapt to very varied systems, up to high-fidelity audio systems, including for professional use. The strong characteristics of this module are its flat response whatever the load, its almost frequency independent distortion and an extremely low EMI radiation rate.
Find in the tab "Download" of this page the complete technical sheet of the product.
The DC offset can be adjusted by turning the potentiometer marked "DC ADJ".
Caution, never turn the potentiometer marked "TTADJ".
Components | |
Capacitors | x10 Hypex For Audio 200µF 100V |
Régulators | HxR Hifh performances regulators |
Amplifier type | Class D Power amplifier |
Output power | 700W @ 4Ω, THD=1% |
THD+N | 0.02% @ 20Hz < f < 20kHz, Pout < Po/2 0.005% @ 20Hz < f < 20kHz, Pout = 1W |
Noise | 30µ |
Frequency response | 10Hz - 50kHz @ +0/-3dB |
Efficiency | > 92% |
Compatible case | Can be mounted in a 2U housing, even on the side |
Recommanded power supply voltage | +/- 90V |
Dimensions | 130 x 79mm x 35.7mm |
Fixing holes spacing | 122 x 71mm |
Weight | 300g |
