IAN CANADA MCDUALXO Multi-Channel Clock Board
The Ian Canada McDualXO is a multi-frequency, multi-channel clock module designed specifically to work with the McFIFO buffer (sold separately) to improve the sound quality of your audio system through the use of ultra-low jitter technologies.
Reference : 17126
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 22-04-2025.
Ian Canada McDualXO
Multi-channel clock board
Ian Canada McDualXO Module d'horloge multi-canaux
The Ian Canada McDualXO is a multi-frequency, multi-channel clock module designed specifically to work with the McFIFO buffer (sold separately) to improve the sound quality of your audio system through the use of ultra-low jitter technologies. The module features automatic Fs switching, dedicated low jitter output buffers, an ultra low noise LDO and a high speed reclocker.
Key features :
  • Has 4 MCLK, 4SCK, 4 LRCL/D1, 2 SD/D2 and each of D3-D8 signals output. The module can therefore drive up to 4 mono block / independent DAC at the same time.
  • 14 channels for I2S or 8 channels for DSD.
  • All outputs are in U.FL coaxial cable connectors/sockets to optimize for signal integrity.
  • Has 3 dedicated and upgradeable ultra-low noise LDOs for XO, clock fan-out buffer and re-clocking. The 0.9µV RMS, 90dB PSRR, 600mA on-board ADM7154 is especially optimized for OCXO.
  • XO frequency range from 11.2896MHz to 98.3040MHz.
  • XOs with different frequency range can work together at same time.
  • XO can be plugged into any socket without limitation.
  • MCLK * Fs range: 128*Fs, 256*Fs, 512*Fs, 1024*Fs, 2048*Fs, 4096*Fs
  • Anti-vibration grommet suspension mechanism design for low jitter applications.
  • Can be stacked on top of McFIFO (sold separately).
Product typeMulti-channel clock board
Dimensions80*70mm
Mounting holes spacing72*36mm
The Ian Canada McDualXO is a multi-frequency, multi-channel clock module designed specifically to work with the McFIFO buffer (sold separately) to...
