Regulateur monté lt1084 au lieu du lt1083 annoncé
LT1084 1.2V / 19.5V 2.5A
The LT1084 regulated DC linear power supply module has been designed to properly power an Amplifier or other continuous audio circuit.
It is equipped with a potentiometer to adjust the voltage from 1.2 to 19.5V DC from an AC voltage source whose value is between 2.5 and 30V AC respectively. The input voltage must be 2.5V higher than the desired output voltage (e.g. 7.5V input to obtain 5V output).
Its particularly rigorous design and the quality of its components make it an excellent choice to power a digital amplifier or any other low voltage high-fidelity element such as certain DAC converters, headphone amplifiers, etc... These are all devices whose sound quality it helps to improve.
Regulator | LT1084 |
Input voltage | 2.5V to 30V AC |
Output voltage | 1.2V to 19.5V DC (2.5A max) |
Capacitors | 1x 10.000µF 50V Nichicon 2x 330µF 25V Nichicon |
Status LED | - |
Dimensions | 116 x 44 x 47mm |
Fixation holes spacing | 107 x 35mm |
Weight | 125g |
Input | Screw terminals |
Output | Screw terminals |
Output voltage (V) | 19.0 |
Output voltage (V) | 15.0 |
Output voltage (V) | 1.0 |
Output voltage (V) | 10.0 |
Output voltage (V) | 5.0 |
Output current (A) | 2.5 |
Input voltage (V) | 25.0 |
Input voltage (V) | 2.5 |
Input voltage (V) | 10.0 |
Input voltage (V) | 20.0 |
Input voltage (V) | 30.0 |
Input voltage (V) | 5.0 |
Input voltage (V) | 15.0 |
Power Supply | Regulated Linear Power Supply |
Average votes 4.3 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Rudolphe D.
Rob S.
Alessio V.
Philippe J.
