Linear Power supply Module DC with heat slug LT1084 1.2V / 19.5V 2.5A
The LT1084 regulated DC linear power supply module has been designed to properly power an Amplifier or other continuous audio circuit.
4.3 / 5
Reference : 11645
24,90 €tax incl.
20,75 € tax excl.
DC regulated linear power supply module
Module d'alimentation linéaire DC régulé LT1083 1.25V / 25V 2.55A
It is equipped with a potentiometer to adjust the voltage from 1.2 to 19.5V DC from an AC voltage source whose value is between 2.5 and 30V AC respectively. The input voltage must be 2.5V higher than the desired output voltage (e.g. 7.5V input to obtain 5V output).
Its particularly rigorous design and the quality of its components make it an excellent choice to power a digital amplifier or any other low voltage high-fidelity element such as certain DAC converters, headphone amplifiers, etc... These are all devices whose sound quality it helps to improve.
RegulatorLT1084
Input voltage2.5V to 30V AC
Output voltage1.2V to 19.5V DC (2.5A max)
Capacitors1x 10.000µF 50V Nichicon
2x 330µF 25V Nichicon
Status LED-
Dimensions116 x 44 x 47mm
Fixation holes spacing107 x 35mm
Weight125g
InputScrew terminals
OutputScrew terminals
Output voltage (V)19.0
Output voltage (V)15.0
Output voltage (V)1.0
Output voltage (V)10.0
Output voltage (V)5.0
Output current (A)2.5
Input voltage (V)2.5
Input voltage (V)10.0
Input voltage (V)20.0
Input voltage (V)30.0
Input voltage (V)5.0
Input voltage (V)15.0
Input voltage (V)25.0
Power SupplyRegulated Linear Power Supply
6 reviews
Moyen
Regulateur monté lt1084 au lieu du lt1083 annoncé
This review has been posted for Linear Power supply Module DC with heat slug LT1084 1.2V / 19.5V 2.5A
Not as described, poor quality control, works once fixed
As of today (4 October 2020), this Audiophonics web item (Ref 11645) is described incorrectly. Of the two linear power supply modules I received in September, neither had an LT1083 regulator installed. They both came with an LT1084 small plastic format. Furthermore one of the regulators was not bolted flush with its heatsink, standing in free space 1.5mm away. Easily fixed, sure. But very poor quality control. As we are dealing with voltage and current (and sensitive, costly connected devices), please check your item carefully once it arrives. Enjoy!
High quality power supply!!!
Very silent and stable power supply!!! Well made with high quality components!!!
Parfait permet un réglage de tension de sortie.
Alimentation pour RPI ou Écran LCD Tactile depuis un an
Ronflette supprimée
Parfait, mon Dac ne ronfle plus.
