SBOOSTER AIB Compatibility Interface Module Kit for Bluesound Node X / N130
The SBooster AIB is a compatibility interface module for the Bluesound Node X / N130 streamer. This SBooster AIB module allows you to upgrade the power supply of your Bluesound device for greatly improved performance by making it compatible with SBooster power supplies.
Reference : 18685
135,00 €tax incl.
112,50 € tax excl.
Shipping date: 17-04-2025.
SBooster AIB picture
The SBooster AIB is a compatibility interface module for the Bluesound Node X / N130 streamer. This SBooster AIB module allows you to upgrade the power supply of your Bluesound device for greatly improved performance by making it compatible with SBooster power supplies. This AIB card sets itself apart from existing upgrade solutions with its maximalist approach to improving every aspect of your network player's power circuitry. This compatibility interface board features a number of high-quality components:
  • SBooster-type C8 connector with gold-plated pins
  • High-purity silver-plated OCC wire
  • Gold-plated PCB connector terminals
  • Dual-stage non-inductive low-pass filters
  • High-performance active filter
  • High-performance hybrid capacitor
  • 2 oz low-impedance gold-plated dual-layer PCB made in Bulgaria
  • Cryo treated fuse for the BOTW P&P ECO MKII 5-6V in the product packag
Photo of SBooster AIB in a Bluesound Node X / N130
Mounting this power supply board inside the Bluesound NODE X / N130 streamer is very simple, requiring only a screwdriver. Among other things, installation of this module enables more detailed sound, with a wider soundstage and immersive bass.
Product typeCompatibility interface module for Bluesound Node X / N130
Input voltage6V
Output rating5V 2A
Connector typeOEM SBooster 2 broches
Package1x Compatibility interface module kit for Bluesound Node X / N130 SBOOSTER AIB
InputIEC C8
OutputPCB Connector
Output voltage (V)5.0
Output current (A)2.0
Input voltage (V)6.0
Power SupplyRegulated Linear Power Supply
The SBooster AIB is a compatibility interface module for the Bluesound Node X / N130 streamer. This SBooster AIB module allows you to upgrade the...
