WONDOM AA-AB41161 Analog to Digital Converter ADC CS5343 I2S 24Bit 96kHz
The Wondom AA-AB41161 is a high-performance signal converter, capable of converting an analog signal into an I2S signal. The signal can then be used with a digital audio system in order to obtain a very high quality sound reproduction.
Reference : 14770
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 25-04-2025.
Wondom CS5343
Wondom CS5343 Module convertisseur analogique vers I2S
The Wondom AA-AB41161 is a high-performance signal converter, capable of converting an analog signal into an I2S signal. The signal can then be used with a digital audio system in order to obtain a very high quality sound reproduction. The input is made on a stereo RCA or on the line input in PH2.0 4-pin format.
Product typeAnalog to I2S converter
Inputs1x Stereo RCA
1x Line input PH2.0 5 pins
OutputI2S
Operating temperature range0°C - 50°C
Thermal protectionShutdown at 150°C
Power supply9V-15V DC via Jack DC
Dimensions91.4 x 68.6mm
InputRJ45
InputPH 2.0mm
OutputI2S
Max sampling rate96kHz
The Wondom AA-AB41161 is a high-performance signal converter, capable of converting an analog signal into an I2S signal. The signal can then be...
