By buying this product you get 39 loyalty points
Automatic Subwoofer Bass Correction DSP Stereo
Get rid of the standing waves that mask the bass in your home theater audio system with the DSPeaker Anti-Mode 8033S-II. Automatically calibrate your system at the touch of a button with this powerful and easy-to-use DSP.
A typical listening room resonates in the low frequencies. For this reason, even the best subwoofer can't reveal its full potential without proper acoustic treatment or correction. Golden Ear award-winning Anti-Mode™ technology eliminates resonance by equalizing responses with precise digital filter structures and anti-phase technology. As a result, the subwoofer can truly express itself all the way to its crossover frequency. In addition, the transient response is also improved for faster, punchier and more controlled bass.
The Anti-Mode 8033S-II is very easy to use. The calibration process is fully automatic. It generates frequency sweeps to the desired calibration point (or multiple points) and measures the combined transfer function of the subwoofer/room assembly.
1 | Microphone input |
2 | Lift button |
3 | Bypass button |
4 | ON/OFF LEF |
5 | Bypass LED |
6 | Lift25 LED |
7 | Lift35 LED |
8 | Power supply input |
9 | Stereo RCA line output |
10 | Stereo RCA Line input |
Product type | Bass correction DSP |
Inputs | 1x Stereo RCA line input 1x Jack 3.5mm microphone input |
Output | 1x Stereo RCA line output |
Correction range | 16Hz-250Hz |
Accuracy | 1/82oct |
Custom filters | 36 |
Correction method | 40bit Arithmetic |
Frequency response | 5Hz-250Hz |
Dynamic range | > 92dB |
Input sensitivity | 1.75Vrms |
Latency | 2.7ms |
Supply voltage | 9VAC or 12VDC |
Dimensions (L*P*H) | 126*80*28mm |
Weight | 230g |
Color | Black |
Package | 1* DSPeaker Anti-Mode 8033S-II 1* Measurement microphone 1* Power supply |
