DSPEAKER ANTI-MODE X2 Room Correction and Equalizer DSP
Compact yet extremely powerful, the DSPeaker Anti-Mode X2 presents itself as a DSP to perform acoustic room correction and equalization tasks with great efficiency. It features the brand new Anti-Mode™ 3 algorithm, capable of automatically optimizing your main speakers and an optional subwoofer to your acoustic environment. This makes it simple and quick to improve the sound quality of an existing HiFi system.
By buying this product you get 62 loyalty points
Reference : 16990
625,00 €tax incl.
520,83 € tax excl.
Shipping date: 25-02-2025.
DSPeaker Anti-Mode X2 DSP Correction Acoustique et Égaliseur
A fully customizable tone control feature is also available, in addition to an advanced digital crossover and subsonic filter. Most features are adjustable in real time using the included remote control. Several sound profiles are also available, allowing quick access to previously saved settings.
An efficient room correction
In order to limit or even cancel the impact of the multiple defects that a listening room can present on the quality of reproduction of an audio system, the DSPeaker Anti-Mode X2 proposes a powerful acoustic room correction system. It uses a microphone calibration system to solve problems such as reverberation, echo, sound reflection, and speaker/subwoofer mismatch, in order to allow your audio system to really shine. This correction is fully automatic and transparent.
Tone control
In addition to its acoustic correction function, the DSPeaker Anti-Mode X2 provides a tone control that allows you to manually adjust the bass, midrange and treble levels. These settings can be saved in three sound profiles that can be accessed at any time.
Easy integration
The DSPeaker Anti-Mode X2 is placed directly between your sources and your amplifier, preamplifier or active speakers. It offers an adapted connectic, composed of a combined RCA stereo/coaxial input, an optical Toslink input and a USB-C port. The digital section supports, thanks to its integrated DAC, audio streams up to PCM 24bit 192kHz.
Concerning the outputs, we find stereo RCA and a subwoofer output. The RCA output offers the possibility of being configured on a variable level for a direct connection with a power amplifier.
1Microphone input
2Display
3IR receiver
412VDC power input
5USB-A input (for firmware update)
6USB-C audio input
7Subwoofer output
8Right channel RCA output
9Left channel RCA output
10Right channel RCA input
11Left channel RCA input / Coaxial input
12Optical input
Product typeRoom correction DsP
Inputs1x Stereo RCA / SPDIF Coaxial ccombo
1x Optical Toslink
1x USB-C
1x Microphone input
Outputs1x Stereo RCA
1x Subwoofer (RCA)
Supported sampling ratesUSB : PCM up to 24bit 96kHz
SPDIF : PCM up to 24bit 192kHz
Frequency range (analog to analog)5Hz-22kHz
Analog input level2.3Vrms (max)
Analog input SNR100dB
Analog input THD (-6dB)< 0.002%
Line output level2.2Vrms (max)
Line output SNR107dB
Line output THD (-6dB)< 0.0015%
Subwoofer output level2.3Vrms (max)
Subwoofer output SNR100dB
Subwoofer output THD (-6dB)< 0.03%
Supply voltage12VDC
Consumption1.5W
Standby consumption0.1W
Dimensions (L*P*H)126*80*28mm
Weight300g
Package1* DSPeaker Anti-Mode X2
1* Measuring microphone
1* Remote control
1* Power supply
Max sampling rateNC
Compact yet extremely powerful, the DSPeaker Anti-Mode X2 presents itself as a DSP to perform acoustic room correction and equalization tasks with...
