MiniDSP BOX 2x4 Balanced Symmetric Audio Processor USB 2 to 4 channels
Reference : 8570
135,00 €tax incl.
112,50 € tax excl.
MiniDSP 2X4 HD Interface
IIR digital filter / DAC 24bit 96Khz
The MiniDSP 2X4HD interface is a processor for digital filtering. It uses a 24 bit / 48kHzDAC (digital / analog converter) & asynchronous USB Audio Class 2.0 input. Like many other miniDSP devices, 2x4 provides powerful, accessible tools to implement a digital filter (IIR Butterworth / Linkwitz Riley 6 to 48dB) and a parametric equalizer. It will suit audiophiles who want to set an effective correction on a pair of stereo speaker. The device can also be used to manage multiple subwoofers in a home theater setup.
In addition to its digital input, the 2x4 in miniDSP has a stereo analog input on phoenix connector for connecting another Hi-Fi device with analog output. Such as a turntable via a RIAA box, or any other analog source. It is a great accessory to centralize the whole installation on a single pair of speakers, while enjoying a correction / filter that extends to the entire chain.
Interface presentation
Plug-in miniDSP 2x4 HD
Audio processor
The 2x4 features a 28 / 56bit floating-point Analog Devices audio processor. The latter allows digital audio calculations as well as control via the USB interface in real time.
The MiniDSP 2X4 provides a complete solution with USB & analog inputs, filtering and parametric EQ.
DSP engine28 / 56bit
DAC / ADC24 bit 48kHz
Connectivity Standardbalanced
analog inputbalanced, switchable with jumper 0.9Vrms and 2Vrms
analog outputsbalanced: Max 0.9Vrms changed to 2V (see manual)
Digital Input / OutputMicro-USB (I2S interface)
capacitorsNichicon
Volume Controlpotentiometer (inside the housing)
PilotUSB Plug & Play with real-time software setup
Dimensions75 x 75 mm
Power supplyJack DC 5.5 / 2.1
Package Contents
Interface miniDSP 2x4HD balancedx1
12V adapter plug UK / EU / US / AUx1
shielded USB cablex1
Code to download the plug-in 2 x 4x1
InputScrew terminals
OutputScrew terminals
Max sampling rate48kHz
3 reviews
Super product and quick delivery from Audiophonics.
Very good and easy to use digital eq/filter. Very good sound.
To bad it´s discontinued from the manufacturer.
Easy business and quick delivery to Sweden from Audiophonics. //Space1999
This review has been posted for MiniDSP BOX 2x4 Balanced Symmetric Audio Processor USB 2 to 4 channels
Correction de mon 1er avis (version KIT)
Attention, souffle constant généré par le mini DSP lui même ainsi que du bruit (click et autre fuzz synchronisé en fréquence avec la led de la carte).
Il n'y a pas de solution pour le stopper: Ni une alim de course, ni Les entrées en court circuit (moins pratique pour écouter de la Musique).
Dès que vous insérer ce PROC dans la chaine du son, les souffles & bruits divers sont clairement audibles.
Pour peu que votre système ait un haut rendement...
Le forum MiniDSP a jeté l'éponge. Il s'agit visiblement d'une erreur de conception ou masse analogique
est commune avec la masse numérique.
Comme le dit le forum MINIDSP, une fois que la Musique joue, on entend plus le souffle...
Il semble que seul le procsymétrique soit incriminé. La version non symétrique RCA n'a parait-il pas ce problème. Ma carte date d'il y a 3 ans.
Pas mieux, imbattable à ce prix!
Utilisé comme filtre actif sur une sono maison, c'est parfait!
Avec le plugin 2x4 advanced Il y a tout ce qu'il faut pour une enceinte 2 voies:
+ 2 filtres crossovers par sortie (Low pass / High pass)
+ 5 equaliseurs paramétriques par voie d'entrée
+ 5 equaliseurs paramétriques par sortie
+ 1 contrôle de niveau par entrée
+ 1 contrôle de niveau + inverseur de polarité + retardateur + compresseur/limiteur par sortie
Ça sonne propre, ça fait ce qu'on lui demande. On peut presque tout corriger. Avec le micro de mesure Dayton UMM-6 (j'imagine que le UMIK est bien aussi) et REW on peut aussi tout mesurer et vérifier la pertinence des corrections. LE TOP!
J'avais déjà la version asymétrique. En mode symétrique c'est pareil, en mieux pour la sono!
