MiniDSP C-DSP 8x12 V2 Audio Processor USB 28/56bit 8 to 12 channels
By buying this product you get 67 loyalty points
Reference : 12206
679,00 €tax incl.
565,83 € tax excl.
Shipping date: 15-04-2025.
Audio Processor USB 28 / 56bit 8 to 12 channels
Mini DSP C-DSP 8x12
the new generation of processor
The MiniDSP C-DSP 8x12 is the next-generation processor for high-end Car Audio. The powerful 400MHz SHARC processor provides high-resolution audio at sampling frequencies up to 192kHz.
With a multitude of inputs and outputs in a sturdy compact 100% aluminum case, the C-DSP 8x12 is perfectly suited for simple stereo systems, surround sound systems with Subwoofer integration, but especially for advanced multichannel active systems.
Advanced settings and simplicity blend
The USB interface that does not require any driver is used to configure the audio processing power of the MiniDSP: EQ parameters on each input and output, adjustable compression and offset on all outputs, filters up to 48dB / octave, and advanced matrix mixer .
QFour full audio processing configurations are stored in flash memory, which are accessible to you instantaneouslyvia the supplied remote control, can be controlled by RJ45 cable or by infrared.
Suitable for car audio world
The car's dedicated hardware features include: an integrated power supply, an I / O for remote triggering, a wired remote control for the instrument panel or console mount, and a card slot micro SD for offline configuration and program updates.
How%20to%20use%20MiniDSP%20C-DSP%208x12_
Connections: Inputs
Analog3x RCA Stereo
digital1x Coaxial SPDIF / 1x Optical Toslink
Connectors: Outputs
Analog6x RCA Stereo
DSPADSP21489
Sampling rate32bits 192kHz
Configuration8 inputs, 12 outputs
Input impedanceHigh level 68Ω / Low level 10kΩ
Output impedance560Ω
Calibration softwareC-DSP 8x12 plug-in
Filtering technologyIIR / FIR depending on the plug-in
Miscellaneous
Dimensions205 x 122 x 41mm
Weight820g
Housing material100% Aluminum
Accessories1x RJ45 Ethernet cable 5m, 2x rack fastenersProfessional with Fasteners, Wired or Infrared Remote Control
Max sampling rate192kHz
