MINIDSP DIRAC SERIES DDRC-88D Audio Processor DSP 7.1 Digital Dirac AES/EBU
The DDRC-88D fits between your digital source and your DAC.
By buying this product you get 119 loyalty points
Reference : 12736
1 199,00 €tax incl.
999,17 € tax excl.
DDRC-88D digital DSP all 8 channels with Dirac Live
A fully digital DSP used with the DAC of your choice
DSP DDRC88D digital front with rotary knob and indicator LED 4
The (optionnal) infrared remote control is not provided. If you need such accomodation you will find a compatible model here.
Like all DSP Dirac Live, DDRC88-8 offers to measure your listening space in all its complexity to automatically apply it several levels of acoustic compensation. In other words, this device is able to hear the specific sound to your installation in a given part to compensate for imperfections (as the resonance frequency of the room, for example, or latency caused by speaker speaker off-axis in a chamber). The processing algorithm is even able to correct variations of freqency and time caused by the physical presence of people listening in the room.
The DDRC-88D and provides a sound surprising clarity that highlights the qualities of a facility rather than its shortcomings. This results in an improved stereo image that unfolds with great sharpness, increased realism, more precise tone and deeper bass.
An accessible yet complete DSP
Dirac Live software
The special live Dirac DSP is to offer an extremely simple configuration method based on the successive positioning of a specific micro following a methodology step by step. In other words, simply tell the software your sound ambitions (life-size movie theater, home theater or listening room) and it will tell you where to position the microphone. Dirac will then automatically take action to "diagnose" the room and installation in comparison with an ideal model. This method of DSP configuration allows a result approaching the acoustic treatment without requiring any work or special knowledge in acoustics.
This stepwise adjustment allows you to enjoy a specifically configured DSP to meet your expectations in terms of problems inherent in your listening / listening room.
Naturally, the DDRC-88D algorithm is capable of handling multiple channels simultaneously. This will be used to configure a DSP sound systems on up to 8 channels (7.1). Automatic configuration of such a facility does not impose additional complexity.
Advanced Manual Configuration
Beyond the automatic configuration (which compares the extent to render ideal reference sound) it is possible to visualize the frequency response measured as well as the proposed correction for each channel. According to their preferences, the user can change the rendering of reference and / or the proposed correction.
Corrrection of frequency magnitude and impulsions
Dirac analyzes the impulse response.
The DRRC-88D DSP can also perform corrections from an analysis of sound pulses. This achieves a high level of accuracy in severe, particularly when it comes to percusifs elements. They will be able to evolve in the musical sound stage rather than in the sound stage of the listening room, which is a marked improvement.
Easy to connect
DB-25
For easy integration into complex systems, DSP DDRC-88D has a very intuitive connection system. DB25 a single cord is connected to the camera body. The latter is divided into 8 to give 4 AES-EBU stereo inputs and four AES-EBU stereo outputs.
In order not to tangling brushes, each of these inputs and outputs is identified by a simple color code.
CanalColor
In 1&2Purple
In 3&4Blue
In 5&6Vert
In 7&8Orange
Out 1&2Yellow
Out 3&4Red
Out 5&6Gris
Out 7&8Brown
Volume Knob
volume knob DSP DRRC-88B
The façade interface is very simple.
A volume knob also serves to select one of the four DSP recorded profiles. 4 LED identify the profile in use.
Processor32bit floating point
Resolution input / output24-bit
Sampling frequencyIndexed on the frequency detected at the first input.If the first input has no signal, 48kHz
Entrance4x stereo AES-EBU (8 channels)
Exits4x stereo AES-EBU (8 channels)
Save settingsYes (4 preset storage locations)
Volume KnobYes
infrared remote controlNot included
remote control functionsVolume + / Volume - / Next Preset / Previous Preset / Mute / Dirac Live on & off
Universal 5V adapterIncluded
InputAES/EBU
OutputAES/EBU
Max sampling rate48kHz
