MINIDSP FLEX Audio Processor DSP Balanced SHARC ADSP21489 XMOS Bluetooth
The miniDSP Flex is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor used previously with a redesigned input/output architecture to offer versatile connectivity. This version features balanced Jack 6.35mm TRS inputs and outputs, as well as a full digital input panel with Bluetooth, USB-B, coaxial and Toslink optical.
4.5 / 5
By buying this product you get 74 loyalty points
Reference : 15885
749,00 €tax incl.
624,17 € tax excl.
Shipping date: 29-04-2025.
miniDSP Flex
miniDSP Flex Processeur Audio DSP Dirac Live SHARC ADSP21489 XMOS Bluetooth
An OLED display on the front panel and a volume controller make it easy to control the unit. Of course, the Flex series incorporates the powerful audio processing features developed by miniDSP: a flexible parametric equalizer, IIR and FIR filters, crossovers, the possibility to program the biquad filter and delay for each output... In addition, all systems can be software enhanced with the Dirac Live® correction solution for fine tuning over the entire frequency range.
The miniDSP Flex offers a wide range of uses and applications, whether in combination with a compact digital stereo preamplifier, for integration with a subwoofer or for active speaker optimization.
The DIRAC licence is not included, but available here.
Test du MiniDSP Flex par Audio Science Review (Amir)
What a nice combination of functionality, usability and performance! As with many DAC companies, it is clearly Minidsp has put strong focus on chasing away sources of noise and distortion. All AV processor and receiver companies lose any excuses they have for not providing this level of performance seeing how the Flex also implements various signal processing modules. "
Product typeDSP
CPUAnalog Devices floating point DSP SHARC ADSP21489 400MHZ
USB InterfaceXMOS
InputsBluetooth
1x USB-B
1x Coaxial
1x Optical Toslink
1x Balanced Jack 6.35mm TRS
Outputs2x Balanced Jack 6.35mm TRS
Supported Bluetooth codecsAAC, SBC, aptX, aptX HD, LDAC
Recording feature via USB4 channel output processing
Processing sampling rate32bit 96kHz
(32bit 48kHz with Dirac Live® license)
Analog input impedance200kΩ
Analog output impedance200Ω
Max input/output levels4Vrms / 4Vrms
Frequency response20Hz-20kHz ±0.1dB
SNR (digital to analog)121dB(A)
THD+N (digital to analog)-112dB (0.00025%) ±3dB
Crosstalk (digital to analog)-128dB
SNR (analog to analog)116dB(A)
THD+N (analog to analog)-108dB (0.0004%) +/-3dB
Crosstalk (analog to analog)-123dB
Filterinf technologyFIR + IIR
Dirac Live® optional: 3x full range correction (20~20kHz)
DSP presetsup to 4 profiles
Supply voltage12VDC 1.6A (power adapter included)
Consumption10.3W
Standby consumption3.1W
Dimensions150 x 180 x 41mm
Package1x miniDSP Flex Balanced
1x Remote control
1x Power adapter
InputJack 6.35mm
OutputJack 6.35mm
Max sampling rate96kHz
2 reviews
L'un de mes meilleurs achats en Hifi !
Je comptais mettre cet appareil entre mon préampli Accuphase et mon ampli mais je suis revenu en arrière rapidement car je trouvait que cela donnait une sonorité métallique au son.
Finalement je l'ai branché en tant que préampli-DAC et là c'est top : c'est le meilleur DAC que j'ai jamais eu et la partie préampli est très bonne, sans compter le fait qu'avec les 2 sorties j'ai pu enfin intégrer/filtrer mon caisson de graves. Bref je suis ravi de cet achat ! Et merci Audiophonics dont le service est toujours au top :-)
This review has been posted for MINIDSP FLEX Audio Processor DSP Balanced SHARC ADSP21489 XMOS Bluetooth
Un peu compliqué mais bluffant avec DiracLive
Une méthode d'activation de licence DiracLive (à acheter séparément) du siècle dernier. Quelques bugs dans le logiciel DiracLive au moment de la calibration (MacOS, d'où les 4 étoiles uniquement) mais le résultat est vraiment bluffant ! Le son des instrument est plus net, plus précis. Quand on désactive la correction, c'est mou, c'est flasque, ça dégouline. Je recommande vraiment. Et merci à l'équipe Audiophonics pour son support.
The miniDSP Flex is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor used previously with...
