MINIDSP FLEX HTx DSP Audio Processor
Big brother of the Flex HT, the Flex HTx from MiniDSP is a 2x8-channel multichannel audio processor perfect for integration into a home theater or multichannel sound system.
By buying this product you get 129 loyalty points
Reference : 18495
1 290,00 €tax incl.
1 075,00 € tax excl.
Shipping date: 16-04-2025.
MINIDSP FLEX HTx
Audio DSP Processor 2x8 Channels SHARC ADSP21489 HDMI ARC eARC
MINIDSP FLEX HTx Audio DSP Processor 2x8 Channels SHARC ADSP21489 HDMI ARC eARC
Big brother of the Flex HT, the Flex HTx from MiniDSP is a 2x8-channel multichannel audio processor perfect for integration into a home theater or multichannel sound system. It features 16 analog inputs, 8 on RCA connectors and 8 on balanced 6.35mm jacks. There are also numerous digital inputs, including USB-B, Toslink optical, SPDIF coaxial and HDMI ARC/eARC. It features a full suite of audio processing functions such as bass management, parametric equalizers, crossover adjustment, advanced biquad programming and delay/gain settings.
In terms of performance, the MiniDSP FLEX HTx achieves a very low level of noise and distortion, making it a device of choice. HDMI ARC/eARC and USB inputs support 8 channels of linear PCM. A front-panel OLED display and volume control knob provide easy control of the device. Settings can be easily modified using Stereo Dirac Live® acoustic correction software (DIRAC license not included, but available here).
Output is via 8 channels on RCA connectors or 8 channels on balanced 6.35mm jacks, with THD+N of just 0.00014% and 0.0001% respectively.
Please note that Flex HTx does not support bitstream decoding (e.g. Dolby/DTS). The audio source must be capable of producing linear PCM (LPCM) for multichannel support via HDMI.
Example of audio installation with MiniDSP FLEX HTx
MiniDSP FLEX HTx rear panel
18x RCA analog inputs
28x Balanced TRS 6.35mm analog inputs
3Trigger 12V jack 3.5mm
4HDMI ARC/eARC input
5DC power supply connector
6USB-B input
7Toslink optical input
8SPDIF coaxial input
98x RCA analog outputs
108x Balanced analog 6.35mm jack outputs
Product type2x8 channels Audio DSP Processor
Inputs8x RCA unbalanced
8x balanced 6.35mm jack
1x HDMI ARC/eARC (up to 8 LPCM channels)
1x USB-B (up to 8 channels)
1x Coaxial (Stereo)
1x Optical Toslink (Stereo)
Outputs8x RCA unbalanced
8x 6.35mm balanced jack
Other connectorsTrigger 12V on jack 3.5mm
ProcessorAnalog Devices SHARC ADSP21489 400MHz 32bit floating point
Interface USB XMOS
USB compatibilityWindows (ASIO driver)
Mac OS
Linux
(Multichannel configuration up to 7.1 channels)
HDMI connectivityARC/eARC (up to 8 LPCM channels)
Supported sampling rates : 32 - 96 kHz
Filter technologyMiniDSP DSP toolbox (routing, bass management, parametric EQ, crossover, gain/delay)
Optional software upgrade to Dirac Live® 3.x Full Range (20 Hz - 20 kHz) multichannel correction
DSP presetUp to 4 presets
CEC controlHDMI CEC control for Mute/Volume/View
Measures
Balanced Jack TRS 6.35mm RCA unbalanced
Analog audio input connectivity8 x TRS balanced8 x RCA unbalanced
Analog audio input impedance200 kΩ100 kΩ
Analog audio output impedance300 Ω150 Ω
Maximum analog input/output level4 Veff/4 Veff2 Veff/2 Veff
Frequency response20 Hz – 20 kHz ± 0,1 dB20 Hz – 20 kHz ± 0,1 dB
Digital to analog (input 1 kHz, 0 dBFS) / AES17 20 kHz LPFRSB127 dB(A)124 dB(A)
THD+N / SINAD-120 dB (0,0001 %) / 120 dB SINAD-117 dB (0,00014 %) / 117 dB SINAD
Crosstalk-132 dB-120dB
TRS analog to analog (1 kHz input, 4 V RMS) / AES17 20 kHz LPFRSB120 dB(A)118 dB(A)
THD+N / SINAD-114 dB (0,0002 %) / 114 dB SINAD-112 dB (0,00025 %) / 112 dB SINAD
Crosstalk-130 dB-120 dB
Supply voltage12V 1.6A
Power consumption16.5 W (idle)
3.7 W (standby)
Dimensions41.5 x 429 x 236mm
Package1x MiniDSP Flex HTX audio processor
1x Remote control
1x External switching power supply 12V 1.6A
InputHDMI ARC
InputJack 6.35mm
OutputJack 6.35mm
Max sampling rate96kHz
Max sampling rate48kHz
Max sampling rate192kHz
Remplace avantageusement les 2 DCX 24-96 pour gérer les 3 voies de mon système
Après avoir mis au point mon filtrage à l'aide de petit Behringer DCX, j'ai choisis de bénéficier du rapport signal/ bruit exceptionnel de ce DSP : 24dB de mieux (encore amélioré sans doute par le recours à un filtre à Supercondensateurs)
Les seuls bémols :
* Seulement 4 presets
* Pas de gestion de la convolution FIR contrairement à d'autres appareils de ce gamme moins ambitieux
This review has been posted for MINIDSP FLEX HTx Audio DSP Processor 2x8 Balanced Channels SHARC ADSP21489 HDMI ARC eARC
Big brother of the Flex HT, the Flex HTx from MiniDSP is a 2x8-channel multichannel audio processor perfect for integration into a home theater or...
