MiniDSP nanoAVR HDA HDMI Audio processor 7.1 USB Ethernet
By buying this product you get 39 loyalty points
Reference : 9832
399,00 €tax incl.
332,50 € tax excl.
The nanoAVR HDA is both a 2-input HDMI audio / video switch and a high-resolution 7.1 / 8-channel audio processor and has 8 analog outputs.
The SHARC ADSP21479, a digital signal processor (DSP) in the heart of the nanoAVR HDA provides an unmatched level for setting eight uncompressed PCM audio channels.
Thee Dolby / DTS decoding should be done from the HDMI source / BlueRay player.
In its most typical application, the nanoAVR HDA connects two HDMI audio sources in PCM format (Blu-ray player for example) to an A / V receiver.
It can be combined with software like Room EQ Wizardand a USB measuring microphone like the Umik-1 for a more precise adjustment.
Real-time configuration is via PC or MAC via USB or via an Ethernet RJ45 connection.
For music lovers wanting to own a studio or a high-end home theater.
This product is compatible with our remote control: Sheet 10901
MiniDSP nanoAVR 8x8 User's Manual
Introducing the MiniDSP Nano AVR 8x8
Introducing the plugin
Android Application
Characteristics :
  • High-resolution processor
  • SHARC ADSP21479 266MHz
  • DAC AKM4440
  • Input Sampling Frequency: 216kHz
  • Output Sampling Frequency: 96kHz
  • Resolution: 32bit
  • Inputs: 2x HDMI 1.4
  • Audio / video + 3D and HDCP support
  • HDMI1.4 output
  • 8 analog outputs RCA 2Vrms
  • Real-time control via USB 2.0 or Ethernet RJ45
  • Compatible with Windows and Mac OS
  • 5V DC power supply included with 2.1 jack
  • Dimensions: 46x161x200mm
