The MiniDSP nanoSHARC can be called a Swiss digital knife, providing a complete solution for the design of high-quality DIY active loudspeakers.
The interfaceMiniDSP nanoSHARCis a processor for2-way active speaker filteringvery evolved in a format of 77x59x11mm. The possibilities offered by this digital filter for speakers with parametric equalizer IIR and FIR are among the best on the market.
Fully digital it will be at leisure to choose its DAC in I2S format. The main use is digital filtering and parametric equalization of a pair of two-way stereo speakers.
Thecomputing power of the processorAnalog Device ADSP12489floating point authorization allows the management of the finite impulse response calculation of the FIR type enabling fine linear digital curve adjustments. It is thus possible to use the conventional technology of type IIR and FIR according to the desired requirements for an optimum result.
le principle is simple: It returns in USB, in optics, in I2S and one comes out in format I2S. The SHARC nano thus makes it possible to get rid of the problems associated with conventional passive filters but also active filters cwith low quality CAD.
This MiniDSP filter is compatible with our NEC RC6 and 38khz remote controls.
For high-quality acoustic measurements, we recommendthe calibrated measuring microphone UMIK-1 USB compatible with the REW software. (microphone sold separately)
APDFis available to describe how nanoSHARC works in download tab.
Warning ! This nanoSHARC is delivered without any plugins.
