TONEWINNER AT-300 EXT 5.1 AV Processor / Home-Theater Preamplifier Dolby Atmos 16 Channels 9.3.4 / 7.3.6
The Tonewinner AT-300 is a 16 channel audio/video processor and preamplifier, ideal for home theater integration in 9.3.4 or 7.3.6 configurations. It supports all current audio formats such as Dolby Atmos, Dolby True HD, DTS:X and DTS Master. Similarly, the AT-300 accepts video streams up to 4K UHD 60Hz and is compatible with HDR, HDR10 and Dolby Vision technologies. It allows you to enjoy the latest and greatest formats available for the most immersive audio and visual experience possible.
By buying this product you get 124 loyalty points
Reference : 17352
1 249,00 €tax incl.
1 040,83 € tax excl.
Shipping date: 07-01-2026.
Tonewinner AT-300 ext 5.1
Tonewinner AT-300 Processeur Audio-Vidéo / Préamplificateur Home Cinéma Dolby Atmos 16 Canaux 9.3.4 / 7.3.6
Tonewinner AT-300 Processeur Audio-Vidéo / Préamplificateur Home Cinéma Dolby Atmos 16 Canaux 9.3.4 / 7.3.6 Tonewinner AT-300 Processeur Audio-Vidéo / Préamplificateur Home Cinéma Dolby Atmos 16 Canaux 9.3.4 / 7.3.6
Advanced video processing
The video processing section for the AT-300's HDMI inputs and outputs uses a Panasonic MN864788 controller. It supports 32bit streams, resolutions up to 4K (3840*2460px) 60Hz and is compatible with RGB/YUV 4:4:4 color spaces.
A powerful audio section
The audio part of the AT-300 relies largely on two Cirrus Logic CS42528 chips, ensuring at the same time the functions of DAC, ADC and SPDIF receiver. These ensure a quality sound reproduction thanks to a wide dynamic range and a very low level of distortion and noise.
SHARC DSP
Combined with these chips, an Analog Devices ADSP-21573 SHARC floating point DSP takes care of decoding Dolby Atmos and DTS:X audio formats to create a truly immersive and consistent sound experience with excellent channel separation.
Precise volume control
Quite rare on this type of device, the volume control is here with resistance switching. Such integration allows a precise and non-destructive adjustment of the sound level.
A breathtaking image
The Tonewinner AT-300 supports all current video technologies and formats. With 18Gbps of bandwidth and HDCP 2.2 compliant HDMI 2.1 connectivity, it easily decodes 4K UHD 60Hz video streams. It also supports HLG, HDR10 and Dolby Vision technologies, bringing an incredible level of brightness and contrast for an exceptional image quality.
Automatic audio calibration
With the ETM-2 measurement microphone (sold separately), the AT-300 is able to automatically calibrate and correct your audio system. The microphone captures the sound information emitted by your speakers and applies automatic equalization to each channel, depending on your listening position.
To go further in the equalization...
In addition to the automatic calibration, it is possible to adjust the equalization manually. Indeed, the Tonewinner AT-300 provides an 11-band parametric equalizer for the left, right and center channels and a 5-band equalizer for the surround, top and bass channels. This equalization can be done directly from the graphical interface of the device.
One memory for each group of inputs
Each group of inputs has an equalizer and independent effects. These different parameters are stored by the device and automatically selected according to the selected input.
Multiple configurations
The Tonewinner AT-300, in order to adapt to different environments, can be used in several configurations: 2.0, 2.1, 5.1, 5.1.2, 5.1.4, 7.1, 7.1.2, 7.1.4, 7.3.6, 9.3.4... So no matter what room you use it in, the AT-300 will fit right in and let you enjoy your audio and video content.
Storage of volume levels
For each channel, the AT-300 allows you to apply a volume level setting and limitations that can be saved and applied as soon as the unit is turned on.
Bluetooth
In addition to a particularly extensive connectivity, the AT-300 integrates a Bluetooth receiver. This one allows a wireless audio broadcast, from a smartphone or a tablet for example. The control of the playback is then done directly from your mobile device for a simple, fast and convenient use.
1RCA outputs
2RCA inputs
3Optical Toslink inputs
4Coaxial inputs
5HDMI output
6Bluetooth antenna
7HDMI eARC output
8Calibration microphone connector
9Micro SD slot
10IR input
115V trigger output
12Mini USB input (USB Audio)
13RS232 interface
14HDMI inputs
15XLR outputs
16Power input
Product typeAudio / Video processor
Home Cinema preamplifier
ChannelsTotal : 16 channels
InputsBluetooth
6* HDMI 2.0
4* Stereo RCA
2* Coaxial
2* Optical Toslink
1* Micro SD slot
1* Mini USB (USB Audio)
1* USB-A (USB Host)
OutputsBluetooth
2* HDMI 2.0 (including 1 eARC)
RCA 9.3.4 channels
XLR 9.1.4 channels
Other connectors1* RS232
1* 5V trigger output
Supported audio formatsDolby Atmos
DTS/X
Dolby True HD
Dolby Digital Plus
DTS Master
DTS Hi-Res
DTS Upmix
DTS Neural X
Supported video formats / resolutions4K UHD
3D
Dolby Vision
HDR10 / HDR10+
HLG
HDCP version2.2
eARC supportOn one output
CEC supportOn 5 inputs
Automatic EQ calibration
Lip SynchronizationUp to 1000ms
DRC function
Input impedance20kΩ
Output impedance1kΩ
Input level≥ 2Vrms
Gain≥ 14dB
THD≤ 0.02% (1kHz)
SNR≥ 98dB (A-Weighted)
Frequency response10Hz-50kHz (+1/-3dB)
Channel separation> 80dB
Crosstalk≥ 80dB
Supply voltage100-240VAC 50/60Hz
Dimensions (L*P*H)431*326*100mm
Weight4.4kg
Package1* Tonewinner AT-300
1* Remote control
1* Power cable
1* HDMI cable 1.5m
1* RCA cable
InputMicro SD
InputHDMI
OutputHDMI
OutputBluetooth
Max sampling rateNC
3 reviews
Le seul dans cette gamme de prix
5 étoiles par rapport au fait que dans cette gamme de prix il n'y a rien d'autre. C'est simple un Marantz c'est 3 fois le prix ou presque.
Sans prendre en compte le prix. :3 étoiles.
-Démarrage ultra lent avec "clic"
-Calibration bof bof
-Clics entre les morceaux en zappant sur Apple Music
-Contrôles limités via l'écran LCD en mode eARC
This review has been posted for TONEWINNER AT-300 EXT 5.1 AV Processor / Home-Theater Preamplifier Dolby Atmos 16 Channels 9.3.4 / 7.3.6
Préampli HC ToneWinnet AT-300
Super. En service depuis deux semaines, l'image est sublime et le son également. Je ne l'utilise qu'en HC et 3.1. Même si l'interface peut paraitre dépassée, tout y est et de toute façon, une fois réglé on y revient dessus que très rarement. Rapport qualité prix imbattable.
Qualité du service et emballage toujours au top.
Merci Audiophonics
agréablement surpris
commende parfaitement traité par audiophonics rien à dire !
En ce qui concerne le processeur je sor d'un Yamaha CX 52àà a 2700 euros et quand j'ecoute celui ci il sonne mieux plus detaillé plus doux le systeme de calibration plus efficafe surtout au niveau des basses a condition de prendre l'option micro EM 2 bref je n'en revienns pas et je doute qu'a ce prix il y est beaoup de concurence
The Tonewinner AT-300 is a 16 channel audio/video processor and preamplifier, ideal for home theater integration in 9.3.4 or 7.3.6 configurations....
