TONEWINNER AT-3000 AV Processor Integrated Home Cinema Amplifier Dolby Atmos 14 Channels 7.1.6 / 9.1.4
Tonewinner's AT-3000 is a 14-channel integrated Audio/Video processor and amplifier, ideal for home cinema integration in 7.1.6 or 9.1.4 configurations. It supports all the current audio formats such as Dolby Atmos, Dolby True HD and DTS:X, as well as all their pretender iterations. Furthermore, the AT-3000 supports video streams up to 4K and is compatible with HDR technology. Finally, 16 line outputs are available if you only want to use the A/V processor to support 9.3.4 or 7.3.6 formats.
By buying this product you get 229 loyalty points
Reference : 19667
2 299,00 €tax incl.
1 915,83 € tax excl.
Shipping date: 16-04-2025.
Tonewinner AT-3000 AV Processor Home Cinema Amplifier Dolby Atmos 14 Channels 7.1.6 / 9.1.4
TONEWINNER AT-3000 : 3/4 View
Tonewinner's AT-3000 is a 14-channel audio/video processor and integrated amplifier, ideal for home cinema integration in 7.1.6 or 9.1.4 configurations. It supports all the current audio formats such as Dolby Atmos, Dolby True HD and DTS:X, as well as all their previous iterations. Furthermore, the AT-3000 supports video streams up to 4K and is compatible with HDR technology. Finally, 16 line outputs are available if you only want to use the A/V processor to support 9.3.4 or 7.3.6 formats.
Tonewinner AT-3000 : Impressive amplification power
Tonewinner's AT-3000 offers a total amplification power of 1680W at 8Ω. This power is distributed so that the right, left and centre channels each receive 240W and the other 8 surround channels each receive 120W.
Tonewinner AT-3000 : State-of-the-art audio section
The AT-3000's audio signal processing is largely based on two Cirrus Logic CS42528 chips, acting as DAC, ADC and SPDIF receiver. These ensure high-quality sound reproduction, thanks in particular to a wide dynamic range and very low levels of distortion and noise.
Two chips Cirrus Logic CS42528
Panasonic MN864788 Controller
TonewinnerAT-3000 : Cutting-edge video processing
The video processing section for the AT-3000's 6 HDMI inputs and 2 outputs uses a Panasonic MN864788 controller. This supports 32bit streams, resolutions up to 4K (3840 x 2460px) 60Hz and is compatible with RGB/YUV 4:4:4 colour spaces.
Tonewinner AT-3000 : SHARC DSP
Combined with these chips, an Analog Devices ADSP-21573 SHARC floating-point DSP decodes Dolby Atmos and DTS:X audio formats to create a truly immersive and coherent sound experience, with excellent channel separation.
DSP SHARC ADSP-21573
Tonewinner AT-3000 : Automatic audio calibration
Thanks to the ETM-2 measurement microphone (sold separately), the AT-3000 is capable of automatically calibrating and correcting the acoustics of your audio system. The microphone captures the sound information emitted by your speakers and applies automatic equalisation to each channel, depending on your listening position.
Tonewinner AT-3000 : Manual calibration
Furthermore, in addition to automatic calibration, you can adjust the equalisation manually to create your ideal sound space. You can also save your various settings and load them at will, so that they always perfectly match the way you use the AT-3000. Note that restoring factory settings does not erase previously saved configurations.
Tonewinner AT-3000 : Volume backup
For each channel, the AT-3000 lets you set volume levels and limits that can be saved and applied as soon as the unit is switched on. This gives you total control to shape your sound space as you see fit.
Bluetooth logo
TonewinnerAT-3000 : Bluetooth
Furthermore, the AT-3000 includes a Bluetooth receiver. This enables wireless audio streaming from a smartphone or tablet, for example. Playback can then be controlled directly from your portable device, making it quick, easy and convenient to use.
Tonewinner AT-3000 : Connectors
TonewinnerAT-3000 : Connector diagram
1RCA line out
2RCA inputs
3Coaxial inputs
4Toslink optical inputs
5HDMI SUB output
6Bluetooth antenna
7HDMI eARC output
8Micro calibration connector
9TF card slot
10IR input
11Trigger output
12Micro-USB input
13RS232 port
14HDMI inputs
15XLR SUB outputs
16Speaker terminals
17Power supply connector
Product typeAudio / Video processor
Integrated Amplifier
Channels14 channel
InputsBluetooth
6x HDMI 2.1
4x Stereo RCA
2x Coaxial
2x Optical Toslink
1x TF card slot
1x Micro-USB
Outputs2x HDMI 2.1
3x XLR SUB
11x Speaker terminals
16x RCA line out
Other connectors1x RS232
1x Microphone calibration connector
1x IR Input
1x Trigger output
Supported audio formatsDolby Atmos
Dolby True HD
DTS/X
DTS Virtual:X
Supported video formats / resolutions4K
3D
eARC
CEC
Standby pass-through
Dolby Vision
HDR10
HDCP version2.2
eARC supportOn an output
CEC supportOn 5 inputs
Automatic EQ calibrationYes
Lip SynchronizationUp to 1000ms
RS232 supportValeur
Output impedance
Output powerLeft, right and centre channels : 240W @8Ω
Surround channels : 120W @8Ω
Gain≥38dB
Total harmonic distortion (THD)≤0.03%
Signal-to-noise ratio (SNR)≥95dB
Frequency response10Hz - 50kHz (+1/-3dB)
Supply voltage110-115V AC 60Hz
220-230V AC 50Hz
Dimensions431 x 439 x 218mm
Weight22.1kg
Package1x Tonewinner AT-3000
1x Remote control
1x Power cable
1x HDMI 4K cable
InputSD Card
InputHDMI
InputHDMI ARC
OutputSpeaker terminal
OutputHDMI
Max sampling rateNC
TONEWINNER AT-3000 AV Processor Home Cinema Amplifier Dolby Atmos 14 Channels 7.1.6 / 9.1.4
Tonewinner's AT-3000 is a 14-channel integrated Audio/Video processor and amplifier, ideal for home cinema integration in 7.1.6 or 9.1.4...
