WONDOM AA-AP23123 ADAU1701 Digital Audio Processor DSP / Preamplifier
This digital audio processor from Wondom uses an ADAU1701 26/58bit DSP chip module. This audio preamplifier/processor features a 2-channel to 4-channel configuration via RCA connectors, as well as a GPIO port for use with an external interface. The front panel also features a number of potentiometers for adjusting different frequencies (HPF/LPF filters) and volume level, and a relative gain potentiometer on the rear panel.
Reference : 18621
42,90 €tax incl.
35,75 € tax excl.
Shipping date: 16-04-2025.
WONDOM AA-AP23123 ADAU1701 Digital Audio Processor DSP Sigmastudio 28/56bit / Preamplifier 2 to 4 channels
Photo of WONDOM ADAU1701
This digital audio processor from Wondom uses an ADAU1701 26/58bit DSP chip module. This audio preamplifier/processor features a 2-channel to 4-channel configuration via RCA connectors, as well as a GPIO port for use with an external interface. The front panel also features a number of potentiometers for adjusting different frequencies (HPF/LPF filters) and volume level, and a relative gain potentiometer on the rear panel. The Wondom ADAU1701 supports Sigma Studio programming via its GPIO port (ICP5), and each control knob is screen-printed according to the corresponding program resources. Dedicated spaces also let you anotate certain specifications to suit your needs. All in all, this digital audio processor offers a complete interface for programming SigmaStudio with the Wondom ICP5 programmer.
Wondom ADAU1701: 2 inputs, 4 outputs with 2-way digital crossover
The Wondom ADAU1701 features a bi-directional digital crossover for precise audio signal distribution. The output stage comprises two dedicated bass channels (DAC0 and DAC1, BANK A) and two dedicated midrange channels (DAC2 and DAC3, BANK B).
Photo of WONDOM ADAU1701 inputs and outputs
Wondom ADAU1701: 4-pot interface for frequency and volume control
The 4 potentiometers of the Wondom ADAU1701 serve as high-pass or low-pass filters and volume control. Two switches are also provided for phase control and mute. Filter setting ranges and potentiometer functionality can be customized via SigmaStudio. Here are the presettings for the various potentiometers on the front panel of the Wondom ADAU1701:
  • POT1 (MP3/ADC2): high-pass filter for the middle output channel, default setting range 3kHz-20kHz
  • POT2 (MP8/ADC3): low-pass filter for bass output channel, default setting range 210Hz-3kHz
  • POT3 (MP9/ADC0): high-pass filter for bass output channel, default setting range 10Hz-310Hz
  • POT4 (VOL): global volume control
Front view of WONDOM ADAU1701
Wondom ADAU1701: full support for Sigma Studio programming
The ICP5 GPIO port coupled with the ADAU1701 DSD chip turns this device into the perfect programming support for SigmaStudio. Wondom has developed an open-source demo program that can be used as a basis and for easily restoring the product to its original parameters using a HEX file.
Photo of SigmaStudio interface
Overview of the WONDOM ADAU1701 DSP digital audio processor
Schéma de présentation du WONDOM ADAU1701
1Power LED indicator
2LED operating indicator
3Switch "MUTE"
4Phase switch
5HPF Bank A (3kHz-20kHz)
6LPF Bank B (210Hz-3kHz)
7HPF Bank B (10Hz-310Hz)
8Volume control
9Relative gain control
10Programming port
115V DC 1A power input via USB-C
12Stereo RCA input
13RCA stereo midrange output
14Stereo RCA bass output
Product typeDSP digital audio processor
DSP ChipADAU1701
Înputs1x Stereo RCA input
Outputs2x RCA midrange output
2x RCA bass output
Maximum input signal level2V
Input impedance10kOhm
Dynamic range98.5dB
Maximum output level0.9Vrms
THD+N0.006%( RCA vers RCA)
Supported sample rates (ADC/DAC)48kHz
Resolution ratio (ADC/DAC)24bit
Frequency adjustment range20Hz-20kHz
Power supply5V 1A via USB-C
Dimensions120 x 121 x 45mm
Package1x WONDOM ADAU1701 Digital Audio Processor DSP
Max sampling rate48kHz
This digital audio processor from Wondom uses an ADAU1701 26/58bit DSP chip module. This audio preamplifier/processor features a 2-channel to...
