HIFIBERRY ADD-ON BOARD DSP Board for HiFiBerry AMP100 / DAC2 HD / DAC2 Pro / Digi2 Pro
This HiFiBerry Add-On DSP card provides digital signal processing capability to tho HiFiBerry AMP100, DAC2 HD, DAC2 Pro and Digi2 Pro modules. The module intercepts the digital stream from the Raspberry Pi to make changes to it, before passing it on to the module it is associated with. It allows access to functions such as IIR and FIR filters, volume control, compressors, equalization, acoustic correction and much more. To access these functions, it is necessary to use the SigmaStudio software.
Reference : 16531
109,90 €tax incl.
91,58 € tax excl.
Shipping date: 22-04-2025.
HiFiBerry Add-On Board
HiFiBerry Add-On Board Module DSP pour HiFiBerry DAC2 HD/DAC2 Pro/Digi2 Pro/Amp 100
This HiFiBerry Add-On DSP card provides digital signal processing capability to the following modules:
  • DAC2 HD
  • DAC2 Pro
  • Digi2 Pro
  • Amp 100
In case you do not want to do this configuration, it is also possible to use the predefined DSP profiles provided by HiFiBerry, using DSP Toolkit.
DSP Toolkit Download and Installlation
The module is directly supported under HiFiBerry OS. With other distributions, it will be necessary to install the DSP Toolkit to program the DSP.
Product typeDSP Board
CompatibilityAMP 100 / DAC2 HD / DAC2 Pro / Digi2 Pro
InputGPIO
OutputGPIO
This HiFiBerry Add-On DSP card provides digital signal processing capability to tho HiFiBerry AMP100, DAC2 HD, DAC2 Pro and Digi2 Pro...
