MiniDSP 2x4 Kit Audio USB processor Unbalanced 2 to 4 channels
Reference : 10107
99,00 €tax incl.
82,50 € tax excl.
This compact 2x4 DSP module can serve both as an active multi-channel filter, processor, source mixer, and ADC / DAC converter.
It has two analogue inputs and four analog outputs.
Combined with a plug-in for programming, it is possible to configure audio processing filters in real time from a PC.
Once the card is configured, the device operates autonomously and therefore does not require the use of a computer.
MiniDSP 2x4 User Manual
Documentation of the MiniDSP 2x4
Introducing the MiniDSP 2x4
Features:
  • DSP 28 / 56bit processor
  • ADC / DAC Converter 24bit 48kHz
    • Dynamic range: 98dB
    • Input Impedance: 6 kOhm
    • Output Impedance: 560 Ohm
    • Switchable asymmetric inputs with jumper between 0.9Vrms and 2Vrms
    • Unbalanced outputs: Max. 0.9Vrms changeable to 2V (see page 6 of the PDF)
    • Digital audio input / output via I2S
    • Nichicon Audiophile Capacitors
    • Volume control by connecting a potentiometer to the 3 pin connector
    • Plug & Play USB driver and real-time software configuration
    • Filtering and EQ via software
    • Dimensions: 75x75mm
    • ### Power supply via USB or DC Jack 5.5 / 2.1mm 4.5 - 24V DC / 150mA
Supplied accessories:
  • 1x shielded USB cable
DOWNLOAD A FREE PLUG-IN FOR THE MINIDSP 2X4:
For a full use of the miniDSP, it is necessary to have a plug-in.
There are several plug-ins available for download right here.
When receiving the product, you will receive in your package the method to follow to download the plug-in of your choice free of charge.
Illustration: version with housing.
https://www.audiophonics.fr/images2/8270/8270_miniDSP2x4_dsp_1.jpg
https://www.audiophonics.fr/images2/8270/8270_miniDSP2x4_dsp_2.jpg
https://www.audiophonics.fr/images2/8270/8270_miniDSP2x4_dsp_3.jpg
DAC / ADC ChipNC
Max sampling rate48kHz
ColorN/A
2 reviews
Great solution for my Bi-Amping DIY project
Just what I needed to tune my DIY two-way active loudspeakers.
This review has been posted for MiniDSP 2x4 Kit Audio USB processor Unbalanced 2 to 4 channels
Efficace
Pour le prix, c'est un très bon ticket d'entrée pour la correction active. Filtre actif, réglage de niveau et de délai, inversion de phase et correction IIR (attention pas de FIR donc pas de correction de la phase).
Bref c'est du tout bon
